[Qgis-developer] WFS Selection UI Improvements
Jeremy Palmer
JPalmer at linz.govt.nz
Mon Apr 1 20:23:15 PDT 2013
Hi QGIS devs,
Do you think it is possible to get this UI improvement merged before 2.0?
https://github.com/qgis/Quantum-GIS/pull/494
Sorry if this type of change was required before the feature freeze, but I've been a little busy over the last few weeks. However I guess it is debatable if this is a feature or a UI change.
One other change that I would like to see in QGIS 2.0 is the ability for the WFS provider to implement the subsetString() method. This would allow users can change the layer attribute filter once the layer has been added map. I'm close to finishing testing on this, but it will take one or two more days to complete. Would it be possible to get this accepted post the feature freeze as well?
Thanks,
Jeremy
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
