[Qgis-developer] best to add a feature on a layer (+ crash)
Nathan Woodrow
madmanwoo at gmail.com
Tue Apr 2 22:44:07 PDT 2013
Denis,
You didn't tell QgsFeature how many attributes it has. You can call
initAttributes(1) or pass in the QgsFields into QgsFeature(fields)
- Nathan
On Wed, Apr 3, 2013 at 3:42 PM, Denis Rouzaud <denis.rouzaud at gmail.com>wrote:
> Hi all,
> I try to add a feature in a layer with only one field (over a few in the
> layer) filled.
> Here is what I tried:
> f = QgsFeature()
> f.setGeometry(myGeom)
> f.setAttribute(1, myValue)
> provider.addFeatures( [f] )
> This causes QGIS to crash.
> What did I wrong? I should not set field 1 if there is a field 0 in my
> feature?
> Should I set the same number of fields as present in the layer?
> Is there another way to achieve this?
> Thanks a lot,
> Denis
> ______________________________**_________________
> Qgis-developer mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130403/bf475f1a/attachment.html>
