[Qgis-developer] Why does the Simplify Feature tool have no normal input field for the tolerance?
Anita Graser anitagraser at gmx.at
Thu Apr 4 13:57:32 PDT 2013
The Simplify Feature tool currently only allows the set the tolerance
using a slider widget. It doesn't even display the tolerance value
anywhere. If a users wants to take notes about the performed processing
steps, he would have no chance with such an interface. I would therefore
like to suggest adding an additional line input field where one can both
read and change the tolerance settings.
What do you think?
Best wishes,
Anita
