[Qgis-developer] Why does the Simplify Feature tool have no normal input field for the tolerance?
kimaidou kimaidou at gmail.com
Fri Apr 5 03:24:52 PDT 2013
Hi all
I do not see about which "simplify tool" you are talking about. When I open
the Vector > Geometry > Simplify geometry , I get this :
http://picpaste.com/Capture_du_2013-04-05_12_22_30-C6KX48vK.png
It is not a slider, but a spinbox, which is fine.
Is there any other simplify tool I have missed ?
Thanks in advance
Michael
2013/4/5 Werner Macho <werner.macho at gmail.com>
> Hi Anita!
> I'll probably take care of this at the HF (If noone else is taking it) as
> i believe that every slider should have a connected spinbox to enter values
> manually ..
> kind regards
> Werner
> On Fri, Apr 5, 2013 at 12:04 PM, Anita Graser <anitagraser at gmx.at> wrote:
>> I opened at ticket at http://hub.qgis.org/issues/**7515<http://hub.qgis.org/issues/7515>
>> and left it as "bug" because I really think that this is an error in the
>> GUI design.
>> Best wishes,
>> Anita
>> Am 05.04.2013, 05:18 Uhr, schrieb vinayan <vinayan123 at gmail.com>:
>>  +1, that would be a good option..for example, in my data, once I know
>>> that
>>> entering 0.05 for the tolerance would be enough to simplify a geometry
>>> to my
>>> requirements, it is tiresome to drag the slider everytime..
>>> View this message in context: http://osgeo-org.1560.n6.**
>>> nabble.com/Why-does-the-**Simplify-Feature-tool-have-no-**
>>> normal-input-field-for-the-**tolerance-tp5044677p5044714.**html<http://osgeo-org.1560.n6.nabble.com/Why-does-the-Simplify-Feature-tool-have-no-normal-input-field-for-the-tolerance-tp5044677p5044714.html>
>>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
>>> ______________________________**_________________
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130405/d4626e73/attachment.html>
