[Qgis-developer] Why does the Simplify Feature tool have no normal input field for the tolerance?
Werner Macho werner.macho at gmail.com
Fri Apr 5 03:52:00 PDT 2013
Hi!
It's in the "Advanced Editing" Toolbox .. when you edit a polygon layer..
kind regards
Werner
On Fri, Apr 5, 2013 at 12:24 PM, kimaidou <kimaidou at gmail.com> wrote:
> Hi all
> I do not see about which "simplify tool" you are talking about. When I
> open the Vector > Geometry > Simplify geometry , I get this :
> http://picpaste.com/Capture_du_2013-04-05_12_22_30-C6KX48vK.png
> It is not a slider, but a spinbox, which is fine.
> Is there any other simplify tool I have missed ?
> Thanks in advance
> Michael
> 2013/4/5 Werner Macho <werner.macho at gmail.com>
>> Hi Anita!
>> I'll probably take care of this at the HF (If noone else is taking it) as
>> i believe that every slider should have a connected spinbox to enter values
>> manually ..
>> kind regards
>> Werner
>> On Fri, Apr 5, 2013 at 12:04 PM, Anita Graser <anitagraser at gmx.at> wrote:
>>> I opened at ticket at http://hub.qgis.org/issues/**7515<http://hub.qgis.org/issues/7515>
>>> and left it as "bug" because I really think that this is an error in the
>>> GUI design.
>>> Best wishes,
>>> Anita
>>> Am 05.04.2013, 05:18 Uhr, schrieb vinayan <vinayan123 at gmail.com>:
>>>  +1, that would be a good option..for example, in my data, once I know
>>>> that
>>>> entering 0.05 for the tolerance would be enough to simplify a geometry
>>>> to my
>>>> requirements, it is tiresome to drag the slider everytime..
>>>> View this message in context: http://osgeo-org.1560.n6.**
>>>> nabble.com/Why-does-the-**Simplify-Feature-tool-have-no-**
>>>> normal-input-field-for-the-**tolerance-tp5044677p5044714.**html<http://osgeo-org.1560.n6.nabble.com/Why-does-the-Simplify-Feature-tool-have-no-normal-input-field-for-the-tolerance-tp5044677p5044714.html>
>>>> Sent from the Quantum GIS - Developer mailing list archive at
>>>> Nabble.com.
>>>> ______________________________**_________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130405/ded96dbd/attachment.html>
