[Qgis-developer] debug qgis mapserver with QtCreator?
G. Allegri giohappy at gmail.com
Mon Apr 8 08:48:55 PDT 2013
2013/4/8 Marco Hugentobler <marco.hugentobler at sourcepole.ch>:
>> but what about POST data?
>> How do you debug it?
> I'm usually debugging GET requests. However, in Qt Creator, you can also
> attach to a running fcgi Prozess.
That's what I was considering right now ;)
Thanks again.
> Regards,
> Marco
> On 08.04.2013 17:34, G. Allegri wrote:
>> Hi Marco,
>> thanks for the tip. That's a starting point, but what about POST data?
>> Yes, I'm aware of the risk for sql-injections ;)
>> giovanni
>>> Hi Giovanni
>>> Just set the environment variable QUERY_STRING (e.g.
>>> QUERY_STRING='SERVICE=WMS&REQUEST=GetCapabilities') and start the
>>> executable
>>> with the debugger.
>>> If you extend the filter possibilities, make sure not to open
>>> possibilities
>>> for sql-injections.
>>> Regards,
>>> Marco
>>> On 08.04.2013 16:56, G. Allegri wrote:
>>>> Hi all,
>>>> I would like to try to extend a bit the filter functionalities in qgis
>>>> server, but I've never setup e debug environment for a C++ CGI.
>>>> Can you suggest me a way to do it? I use QtCreator (Linux) for QGis
>>>> Desktop and I will like to employ iy here too, but I can't figure how
>>>> to attach it to the CGI executable...
>>>> thanks,
>>>> Giovanni
>>> Dr. Marco Hugentobler
>>> Sourcepole -  Linux & Open Source Solutions
>>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>> Technical Advisor QGIS Project Steering Committee
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Giovanni Allegri
http://about.me/giovanniallegri
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
