[Qgis-developer] Postgis Multipolygon :: cannot create a feature
Régis Haubourg
regis.haubourg at eau-adour-garonne.fr
Tue Apr 9 05:18:27 PDT 2013
That would be a good idea, and I really think it could be a blocker because it leads to dead-end when editing, and sometimes leads to data loss. ( Joeren already solved that critical issue, because postgres provider dropped rows before inserting new rows, and all was lost if a constraint error was raised)
Régis
De : 3nids [via OSGeo.org] [mailto:ml-node+s1560n5045482h2 at n6.nabble.com]
Envoyé : mardi 9 avril 2013 14:12
À : HAUBOURG
Objet : Re: Postgis Multipolygon :: cannot create a feature
Shall I fill an issue?
On 04/09/2013 02:10 PM, Régis Haubourg wrote:
> +1 with you Denis. This restriction also implies severe known bugs when using
> merge or clip tools that creates POLYGON and not MULTIPOLYGON.
> Currently, I solve this by modifying postgis constraint so that it accepts
> POLYGON or MULTIPOLYGON. Bu this is a bad practice.
> I would really prefer that QGIS automagically propose multipolygon (or multi
> point, or multilinestring) when a multi geometry type as been declared when
> loading layer.
> Régis
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Postgis-Multipolygon-cannot-create-a-feature-tp5045473p5045480.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
> [hidden email]</user/SendEmail.jtp?type=node&node=5045482&i=0>
[hidden email]</user/SendEmail.jtp?type=node&node=5045482&i=1>
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Postgis-Multipolygon-cannot-create-a-feature-tp5045473p5045482.html
To unsubscribe from Postgis Multipolygon :: cannot create a feature, click here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5045473&code=cmVnaXMuaGF1Ym91cmdAZWF1LWFkb3VyLWdhcm9ubmUuZnJ8NTA0NTQ3M3w0NjAxMTYx>.
NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Postgis-Multipolygon-cannot-create-a-feature-tp5045473p5045490.html
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130409/54b8b1c3/attachment-0003.html>
