[Qgis-developer] Label backgrounds (shape, SVG, drop shadow)
    Werner Macho
    werner.macho at gmail.com
    Thu Apr 11 10:26:52 PDT 2013
As far as I can tell there will probably be a few other API changes during
the hackfest..
So from my point of view there should be all API breakages done before 2.0
release.. Which actually means now..
+1 from me for doing the changes..
And applying the "hard" freeze after the hackfest..
Tim? You have the last word..
Kind regards
Werner
Am 11.04.2013 20:08 schrieb "Larry Shaffer" <larrys at dakotacarto.com>:
> Hi,
> So I've now got drop shadows working for all label components: text,
> buffer, and background shape and SVG [0]. I realize this is obviously late,
> but the changes also introduce a small container class for temporal
> labeling data that stabilizes the API [1]. In this way, the calls should
> not change even after most label components are migrated to the symbology
> classes (between 2.0 and 2.1) in preparation for a rule- and style-based
> setup.
> If I can still commit this to master, I'll clean it up and do so today. If
> not, that's cool, it can wait. Then, I'll focus on the belated GUI updates
> and labeling bug fixes.
> [0] https://www.dropbox.com/sh/b70bfsxcs6rl66v/ir70Y33UF5
> [1] https://github.com/dakcarto/Quantum-GIS/commits/labeling_dropshadow_6
> Regards,
> Larry
> On Tue, Apr 9, 2013 at 3:58 AM, Marco Hugentobler <
> marco.hugentobler at sourcepole.ch> wrote:
>>  Hi Larry
>> +1 for pushing the drop shadows to master.
>> >Does switching over the data defined backend for labeling constitute a
>> new feature? If not, I'd like to work on it over the next week.
>> Tim as release manager needs to decide here.
>> >* Significantly missing functionality currently occurs in the data
>> defined aspect of new labeling features. Many of the new features do not
>> have corresponding data defined options, and the current gui >and usage of
>> the data defined values does not mirror that of the new setup by recently
>> committed by Dr. Marco H for symbology. Since labeling does not yet have a
>> rule-based setup, it would be *very >good* to have the current data defined
>> setup for labeling switched over to Marco's method. This will allow
>> expressions to be used for all labeling options and give users a solid
>> feature set for labeling >to work with until 2.1.
>> Something related is to have classified label styles. Often it is
>> necessary to apply multiple label styles in one layer depending on
>> attribute expressions (kind of rule based renderer for labels). Maybe in
>> 2.1...
>> Regards,
>> Marco
>> On 09.04.2013 04:52, Larry Shaffer wrote:
>> Hi,
>>  Here's an update on the labeling work I've been doing for the past week:
>>  * Label backgrounds (geometric shapes and SVG) have been
>> implemented/committed, but currently have a couple of loose ends [0].
>>  * Label drop shadows are essentially functional, and work for label
>> buffers [1]. I need a couple of days to clean up the overly verbose code,
>> simplify the logic and make it work for label text and backgrounds. In the
>> GUI and map canvas screen snaps [2][3] you can see an example of the radius
>> blurring and of the 'global' offset option (there are also debug rectangles
>> shown). When global is checked for shadow offset, rotated label's drop
>> shadows are adjusted to match the global offset for the layer (instead of
>> being relative to the label's rotation). For example, this allows all drop
>> shadows on all labels, or their buffers/backgrounds, to match what a user
>> may have setup in a hill shaded raster, i.e. opposite the angle of a
>> virtual sun. Turning on all these features does slow labeling down, of
>> course.  :^)
>> have corresponding data defined options, and the current gui and usage of
>> rule-based setup, it would be *very good* to have the current data defined
>> feature set for labeling to work with until 2.1.
>>  So, I have a couple questions:
>>  Can I push the cleaned up and functional labeling drop shadows work to
>> master branch in a couple of days, for inclusion in 2.0? It was my
>> understanding this was part of the labeling background work I was
>> temporarily allowed to do, but it has taken a couple of days longer than
>> expected.
>> If switching over the data defined backend is considered a new feature,
>> and not allowed to be committed right now, can I at least work on adding
>> some of the missing data defined options for labeling?
>> [0] https://github.com/qgis/Quantum-GIS/commit/b8097239
>> [1] https://github.com/dakcarto/Quantum-GIS/commits/labeling_dropshadow_4
>> [2] http://drive.dakotacarto.com/qgis/labeling_drop-shadow-options.png
>> [3] http://drive.dakotacarto.com/qgis/labeling_drop-shadows.png
>>  Regards,
>>  Larry
>> On Sat, Mar 30, 2013 at 12:18 PM, Andreas Neumann <a.neumann at carto.net>wrote:
>>> Hi,
>>> I'd love to have these label backgrounds and drop shadows in QGIS 2.0.
>>> Makes sense to me to include this work despite feature freeze since a
>>> major effort was made already to improve labeling in QGIS 2.0.
>>> so +1 from my side.
>>> Thank you for your work, Larry.
>>> Andreas
>>> Am 30.03.2013 12:32, schrieb Larry Shaffer:
>>> > Hi,
>>> > In an effort to bring a basic label background feature into 2.0 before
>>> for
>>> > the freeze, I figured out a good approach that makes adding label
>>> > backgrounds much easier (better late than never, I suppose) [0]. This
>>> means
>>> > that adding SVGs and drop shadows for label backgrounds is only an
>>> extra
>>> > couple of days of work.
>>> > Here's a preliminary gui setup [1] (not all may be implemented, but
>>> most
>>> > can easily be).
>>> > An example of generic rounded-corner rectangles (a la web mapping and
>>> many
>>> > road shields) with a bit of x/y offset to nicely center the text [2].
>>> > And, an example of the 'centering' of the background relative to the
>>> label
>>> > contents (background rotated 90 deg relative to text) [3], regardless
>>> of
>>> > label's offset placement (see pink-text label next to point feature).
>>> This
>>> > is a crucial feature for integrating many types of backgrounds.
>>> > Both examples also show one issue: while labels don't overlap due to
>>> > collision management, their backgrounds might overlap each other or
>>> > previously drawn label text. I believe this is fixable, though I don't
>>> know
>>> > how long it will take, off hand.
>>> > So... basically, I'm asking those who make decisions whether I can
>>> work for
>>> > another week on this feature, for inclusion in 2.0.
>>> > [0]
>>> https://github.com/dakcarto/Quantum-GIS/commits/labeling_bkgrd-symbols_3
>>> > [1] http://drive.dakotacarto.com/qgis/labeling_background-gui.png
>>> > [2] http://drive.dakotacarto.com/qgis/labeling_background-rounded.png
>>> > [3] http://drive.dakotacarto.com/qgis/labeling_background-rotation.png
>>> > Regards,
>>> > Larry Shaffer
>>> > Dakota Cartography
>>> > Black Hills, South Dakota
>>> > _______________________________________________
>>> > Qgis-developer mailing list
>>> > Qgis-developer at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Dr. Marco Hugentobler
>> Sourcepole -  Linux & Open Source Solutions
>> Weberstrasse 5, CH-8004 Zürich, Switzerlandmarco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>> Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130411/2a810a2e/attachment-0001.html>
