[Qgis-developer] Ideas on the SVG symbols library
Andreas Neumann
a.neumann at carto.net
Fri Apr 12 23:55:41 PDT 2013
Hi Olivier,
Yes, version A is better - as you more easily add a different background
or combine it with another SVG background symbol.
Thank you for starting this work.
Andreas
Am 13.04.2013 00:05, schrieb Anita Graser:
> +1 for A
> Thanks for the initiative!
> Anita
> On Fri, Apr 12, 2013 at 10:03 PM, Olivier Dalang
> <olivier.dalang at gmail.com>wrote:
>> Hi !
>> My last email about SVG symbols did not get a lot of answers ;) So I try
>> again...
>> I'm still thinking about reworking the SVG library a little bit for 2.0,
>> but before starting that dull work, I'd like to be sure that there's some
>> agreement about the best strategy.
>> I've two variants (illustrated by the screenshot), explained in details
>> below. Of course the variant 0 (doing nothing at all) also exists
>> https://www.dropbox.com/s/bfdncq9an8i6mc5/comparison.png
>> Personally, I vote for variant A, excepted if alpha values work in variant
>> B.
>> Cheers,
>> Olivier
>> *Variant A*
>> - Remove the backgrounds from every symbol.
>> - Add the fill, outline, and outline-width params to every symbol.
>> - Make all symbols initial size the same.
>> - Add some new SVG backgrounds
>> Pros :
>> - very flexible (add, combine, ...)
>> Cons :
>> - slightly more complex for beginners
>> - old project files won't look the same (the icons won't have a background)
>> *Variant B*
>> - Add the fill and outline params to every symbol, having the outline
>> param actually apply to the background.
>> Pros :
>> - almost the same than today (so no changes for old projects files and
>> nothing new to learn)
>> Cons :
>> - Its seems a bit wrong to use an "outline" color param, to set a
>> backgorund color.
>> Questions :
>> - Would it be possible to have alpha values in the color selector ? So you
>> could choose to have a transparent background, and get almost all benefits
>> of variant A. (I don't know the way the SVG symbols work in the code enough
>> to try that)
>> *Variant A&B*
>> - Run SVG cleaner on all symbols (not sure if there's any benefit, but
>> it's not much work)
>> - Remove some word 95 looking symbols (golf flag, backpacker, ... )
>> - Remove some duplicate icons (same icons with different colors, ...)
>> - Reorganize some icons ("Symbol" fold is not a very explicit name)
>> Questions :
>> - Are the GPS icons part of some kind of standard ? Or is it OK to
>> remove/reorganize those as well ?
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
