[Qgis-developer] Has the blending behavior changed in the last few days?
Nyall Dawson
nyall.dawson at gmail.com
Sat Apr 13 13:50:21 PDT 2013
On 14 April 2013 01:46, Anita Graser <anitagraser at gmx.at> wrote:
> Hi,
> Has the blending behavior changed recently? I had created a map with a
> hillshade and a vector style overlaid using "multiply". It looked fine. But
> with today's nightly, the blending mode is applied to the single symbol
> levels of my vector layer which messes up everything. It's imho impossible
> to use symbols with multiple layers if the blending stays this way.
As far as I'm aware nothing should have changed recently. Are you
seeing this in a composer or the standard map window? Can you please
file a bug with your data & project and I'll sort this out.
Thanks!
