[Qgis-developer] problem with feature request and updateFeature
Nathan Woodrow
madmanwoo at gmail.com
Mon Apr 15 16:01:07 PDT 2013
I asked Jurgen to add the updateFeature a while ago in order to make the
API feel a bit cleaner. My issue was that you could update the attribute
values on the feature but you then still call changeFeatureAttribute for
each attribute which seems really crap. I really only want to update the
feature and give it to the layer to handle calling the
changeFeatureAttribute calls with the id, index, value stuff.
- Nathan
On Tue, Apr 16, 2013 at 8:13 AM, Martin Dobias <wonder.sk at gmail.com> wrote:
> Going back to the older thread....
> On Sat, Mar 23, 2013 at 7:19 PM, Jürgen E. <jef at norbit.de> wrote:
> > On Sat, 23. Mar 2013 at 09:49:28 +1000, Nathan Woodrow wrote:
> >> Well the feature itself knows what values it started with. Every update
> in
> >> QgsFeature goes though the setAttribute, etc, call, you can just have an
> >> internal dictionary that logs when one of values is changed using those
> >> methods.
> > Sure, you could do that. But what for? Just for updateFeature? That
> method
> > is not even used anywhere.
> > And one instance of QgsFeature is often used as buffer, so the tracking
> would
> > have to be reset at some point (setValid? setFeatureId?).
> > IMHO one needs to be aware that currently multiple iterators are not
> working
> > for now. Maybe Martin can comment on this - I guess he has plans
> continue to
> > work on this and the current state is for the time being.
> Maybe we should simply remove the updateFeature() function (or at
> least clearly document the side effect of issuing a request to the
> provider). Because of that request, even if the function worked in the
> nextFeature() loop, it would be highly inefficient to update features
> in such loop due to the many separate queries to the backend.
> Another reason for its removal would be that we do not use it anywhere
> in QGIS codebase and it's questionable to what extent it worked before
> the new vector API merge. For example, several providers used the same
> cursor for featureAtId() and nextFeature(), so the featureAtId() call
> during nextFeature() loop would re-create the cursor. Moreover,
> although OGR has a separate API calls for featureAtId(), OGR drivers
> that do not have efficient implementation of "get-feature-at-id" will
> simply fall back to internal "get-next-feature" loop, invalidating the
> reading state of nextFeature() loop.
> I have commented on multiple iterators in the other thread.
> Martin
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130416/0ca04c51/attachment.html>
