[Qgis-developer] Icon theme update
Noli Sicad nsicad at gmail.com
Mon Apr 15 19:59:05 PDT 2013
Hi Larry,
OK. Thanks for clarification.
I understand the decision to have a one theme. That's is fine.
However, I like to do my own compile version with nkids in Mac OS X
later on. Is it possible. I like to see first are the set of icons
needs to be done.
Thanks.
Noli
On 4/16/13, Larry Shaffer <larrys at dakotacarto.com> wrote:
> Hi Noli,
> On Mon, Apr 15, 2013 at 7:00 PM, Noli Sicad <nsicad at gmail.com> wrote:
>> Hi Larry,
>> What is the summary of this posting?
> Some time ago, devs voted to move to the 'gis' theme as the default, i.e.
> not just the one selected by default but also the only theme supported by
> the project. Even after this update, you may notice the icons are still
> hodge-podge with inconsistent ones needing work. Due to lack of developers
> to maintain multiple project-supported themes, it is best to have only one,
> so that a concerted effort can be made to keep it complete and cohesive.
> Does mean that we can use themes in QGIS 2.0?
> No theme support code was removed, only the gis theme condensed upon the
> current default (because many default icons are still used) and old project
> themes removed. However, there has been talk of removing all theme support,
> but I can't speak to the state of that decision.
> I like to revive my nkids theme for QGIS 2.0 as option for Mac OS X
>> QGIS, is this possible?
> I'm not entirely sure, but to use a different theme than the default, you
> will need to add it to the appropriate source directories, edit the .qrc
> files and compile the source again. For example, nkids has been in the
> source themes directory for awhile, but not choose-able in the gui because
> it is not been made part of compiled-in resource system.
> I did add some code to push any old saved theme choice over to the new
> default, so if you did add a revamped nkids theme, maybe considering giving
> it a new name as well.
> If I am misunderstanding the current state of decisions regarding the move
> forward for icon themes, somebody please correct me (see also [0]).
> Regards,
> Larry
> [0] http://hub.qgis.org/issues/7551
> Thanks.
>> Noli
>> > Hi,
>> > So, I've pushed a large update to master that condenses down the
>> > default
>> > icon theme by overriding it with the gis theme (the theme voted to be
>> > the
>> > replacement). I apologize if the change is abrupt, but it needed done
>> with
>> > enough time to edit/fix things before 2.0 release.
>> > I did this in the following manner:
>> > 1) Copied the gis theme over the default theme. Any files of same name
>> were
>> > replaced, missing files added. The was done for plugins that also
>> > managed
>> > icon sets per theme (grass, georeferencer and ftools).
>> > The state of previous icon theme sets and directory structure are
>> preserved
>> > as a download here [0] (saves switching local or browsing online git
>> > repo
>> > to find replaced/removed ones). These can be added back to source
>> > directory, for reference, or not.
>> > 2) Updated all appropriate .qrc and .ui files that referenced old theme
>> > paths.
>> > 3) Switched some icons to improve consistency (mostly to + and - icons
>> for
>> > table widget row editing)
>> > 4) Proofed every dialog I could think of, though I'm sure I missed
>> > something. This was from both running from build directory and from
>> > installed app on Mac.
>> > 5) Added some code to ensure any old saved theme choice now goes to
>> > default. No theme support code was removed.
>> > 6) Updated CMakeList.txt files to ensure SVGs are also copied on
>> > install.
>> > Where to go from here:
>> > * Please, let me know if I made a mistake somewhere.
>> > * We now have a single set of icons on which to work and update. Icons
>> > should be updated, especially those that don't match current theme.
>> > * Moving to SVG can be aided by leaving the getThemeIcon/Pixmap calls
>> > and
>> > referencing the file by base name, without extension, e.g.
>> > QgsApplication::getThemePixmap( "pie-chart" ). When using this
>> > technique,
>> > as soon as a .png is replaced with a .svg in a .qrc resource file, it
>> > is
>> > auto-found, without having to edit anymore code. Let me know if this
>> > approach should be used.
>> > [0]
>> http://drive.dakotacarto.com/qgis/QGIS-images_pre-gis-theme-switch.zip
>> > Regards,
>> > Larry
