[Qgis-developer] [Qgis-user] How define the "other" condition on a classification render
Anita Graser
anitagraser at gmx.at
Wed Apr 17 04:34:00 PDT 2013
Wouldn't it make sense to translate the old style into a rule-based
renderer? There it's easy to define a style for "other".
Best wishes,
Anita
On Wed, Apr 17, 2013 at 11:42 AM, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi,
> I have fill a ticket with a sample to show how a map of qgis 1.8.0 if
> lost on a qgis 1.9.0 after an import.
> http://hub.qgis.org/issues/7630
> 2013/4/17 Alexandre Neto <senhor.neto at gmail.com>
>> You should be.
>> I tested myself and I believe you found a bug.
>> You should be able to add a new class without any value, and all values
>> outside the existing categories should be rendered with that symbology.
>> Thats how it works in 1.8.
>> I'm not being able to open qgis.org (probably is under maintenance), but
>> if there is no issue ticket for this problem, we should create one.
>> Alexandre Neto
>> On Tue, Apr 16, 2013 at 10:15 PM, Andrea Peri <aperi2007 at gmail.com>wrote:
>>> Hi,
>>> I'm using the qgis-dev version of qgis.
>>> Is possible to define the 'other values' condition in the
>>> "categorized" style ?
>>> Thx
>>> Andrea Peri
>>> qwerty àèìòù
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Andrea Peri
> qwerty àèìòù
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130417/1113d757/attachment-0001.html>
