[Qgis-developer] behavior of splitting feature
    Andreas Neumann
    a.neumann at carto.net
    Mon Apr 22 11:51:24 PDT 2013
I would propose that the editing stuff should go into QGIS core. It is
cumbersome having to download plugins all the time for editing.
I would also suggest to implement the CAD stuff in QGIS core. I can't
see why someone does not want to have these improvements.
That way the tools get more exposure to both users and developers.
Andreas
Am 22.04.2013 17:14, schrieb Alexandre Neto:
> You can use Multipart Split Plugin to split the selected multipart features.
> http://plugins.qgis.org/plugins/splitmultipart/
> Alexandre Neto
> On Mon, Apr 22, 2013 at 3:07 PM, Denis Rouzaud <denis.rouzaud at gmail.com>wrote:
>> Hi,
>> I am dealing with multi polygons these days, and I find very annoying to
>> not being able to split a part into several part.
>> First, am I right saying it's not feasible?
>> If yes, I would like to propose to add a choice to the splitting tool:
>> - split into several features
>> - split into several parts (only availbale for multi-polygon/lines layers)
>> Would you agree on this?
>> Then, how to propose this to the user?
>> 1. Choice dialog after drawing the split lines (propose only if layer has
>> multi geometry)
>> I think everybody agrees it's a bad option
>> 2. Have two icons and two separate tools
>> Nice to use, but not to right direction in terms of number of icons in QGIS
>> 3. Have a drop down icon as for the selection tool.
>> My suggestion.
>> If drop-down is the chosen option, I would also suggest to group add part
>> with add ring, and also delete part with delete ring. It would therefore
>> more coherent.
>> Greetings,
>> Denis
>> ______________________________**_________________
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
