[Qgis-developer] Make QGIS interact with LibreCAD.
Ramon Andiñach custard at westnet.com.au
Mon Apr 22 15:34:21 PDT 2013
On 22/04/2013, at 20:40 , Ziegler Stefan wrote:
> I would like to see some changes in the snapping interface. If you got some 30+ layers it is really difficult to find a specific layer. A layer tree for snapping just like for the legend would be great. And add the tree as tab like the browser.
On 22/04/2013, at 20:50 , Antonio Locandro wrote:
> I remember when I used AUTOCAD the thing that I really liked about it is that
> a. I can draw pretty fast and accurate using only commands but had the icons if I wanted
> b. Snapping is one of the best I used, you can interactively set the snapping while digitising like snap to end, snap to midpoint, snap to edge, etc.
Interestingly b is possible, but you have press apply all the time for changes to come in, and the snapping options window gets in the way a lot.
Maybe if you could dock the snapping options under the layer list, and changes auto applied, that would help a bit.
-ramon.
