[Qgis-developer] Possible memory leak in rendering code
Ivan Mincik ivan.mincik at gmail.com
Tue Apr 23 02:43:35 PDT 2013
On 04/23/2013 11:05 AM, Andreas Neumann wrote:
> Hi,
> How comes that the same feature works fine for some but is broken for
> others?
> When I have it on (using a combination of Postgis, WMS and GeoTiff) I
> often have redraw issues and the layer toggeling often fails. Layers are
> not drawn, but appear to be on with the checkbox in the layer tree or
> vice versa. I think the main problem is when also using WMS sources.
Yes, I see the same layer redrawing problems when using WMS and PostGIS
layers.
Ivan Mincik
