[Qgis-developer] OSGeo4W QGIS 1.8 Doesnt Work
Stott James
fmrojst at fylkesmannen.no
Wed Apr 24 01:25:20 PDT 2013
I install QGIS from the OSGeo4W installer.
Does that mean I need to wait for a rebuild of QGIS to be put out in the installer?
James
-----Opprinnelig melding-----
Fra: Alexander Bruy [mailto:alexander.bruy at gmail.com]
Sendt: 24. april 2013 10:13
Til: Stott James
Kopi: qgis-developer at lists.osgeo.org
Emne: Re: [Qgis-developer] OSGeo4W QGIS 1.8 Doesnt Work
seems this caused by recent Python upgrade in OSGeo4W. I think rebuilding QGIS will solve this issue.
On Wed, 24 Apr 2013 08:09:45 +0000
Stott James <fmrojst at fylkesmannen.no> wrote:
> Hi all,
> I have noticed that since I updated OSGeo4W yesterday, I cannot launch QGIS 1.8. It stops loading when the splash screen gets to Loading Python.
> I also get the following error when trying to run a python script from the OSGeo4W shell:
> G:\>zip_data_test.py
> Traceback (most recent call last):
> File "C:\OSGeo4W\\apps\Python27\lib\site.py", line 563, in <module>
> main()
> File "C:\OSGeo4W\\apps\Python27\lib\site.py", line 545, in main
> known_paths = addusersitepackages(known_paths)
> File "C:\OSGeo4W\\apps\Python27\lib\site.py", line 278, in addusersitepackages
> user_site = getusersitepackages()
> File "C:\OSGeo4W\\apps\Python27\lib\site.py", line 253, in getusersitepackages
> user_base = getuserbase() # this will also set USER_BASE
> File "C:\OSGeo4W\\apps\Python27\lib\site.py", line 243, in getuserbase
> USER_BASE = get_config_var('userbase')
> File "C:\OSGeo4W\apps\Python27\lib\sysconfig.py", line 472, in get_config_var
> return get_config_vars().get(name)
> File "C:\OSGeo4W\apps\Python27\lib\sysconfig.py", line 405, in get_config_vars
> import re
> File "C:\OSGeo4W\apps\Python27\lib\re.py", line 105, in <module>
> import sre_compile
> File "C:\OSGeo4W\apps\Python27\lib\sre_compile.py", line 14, in <module>
> import sre_parse
> File "C:\OSGeo4W\apps\Python27\lib\sre_parse.py", line 17, in <module>
> from sre_constants import *
> File "C:\OSGeo4W\apps\Python27\lib\sre_constants.py", line 18, in <module>
> from _sre import MAXREPEAT
> ImportError: cannot import name MAXREPEAT
> Does anyone here know how to fix this? Is this a problem for the OSGeo4W people instead?
> Many thanks,
> James
Alexander Bruy
