[Qgis-developer] Fields/attributes
Andreas Neumann
a.neumann at carto.net
Fri Apr 26 00:03:24 PDT 2013
The shape files should not constrain us with the column length anymore.
Meanwhile, QGIS-Dev (master) even handles the column shortening and
conflict detection (if shortened columns collide because of the
shortening) correctly. This wasn't the case in older versions. Thanks to
whoever fixed that!
Personally I would avoid characters outside of the [a-zA-Z_] range in
column names. Some formates may have troubles with these other
characters.
Andreas
On Fri, 26 Apr 2013 08:41:45 +0200, Albin Blaschka wrote:
> Hello,
> sorry for intervening as an outsider...but maybe a tiny
> contribution...
> Am 26.04.2013 02:39, schrieb Nathan Woodrow:
>> Hey Chris,
>> 1) I don't think there is any limit. The name is just stored as a
>> QString so anything it supports QGIS should too.
> There are some limits in shapefiles concerning names in the attribute
> table, coming from the dbf - format. So, if at first the column names
> are e.g. longer than the eight characters allowed in dbf, and the
> user
> stores the data later as a shapefile, in this way, a problem could
> maybe arise, especially if the long names are similar at the
> beginning...
> regards,
> Albin
>> 2) I have noticed that too it is quite confusing at times. To me
>> fields
>> should refer to the column information, and attributes should refer
>> to
>> the data it self, but that is not always the case in the API.
>> - Nathan
>> On Fri, Apr 26, 2013 at 10:33 AM, Chris Crook <ccrook at linz.govt.nz
>> <mailto:ccrook at linz.govt.nz>> wrote:
>> Couple of questions with regard to QgsFeature fields and
>> attributes:
>> 1) Are there any guidelines/constraints regarding field names.
>> The
>> delimited text provider can take names from the first line of a
>> text
>> file, and that can be very arbitrary. I'm wondering if I should
>> put
>> more constraints on the names (maximum number of characters,
>> valid
>> character set, other...)
>> 2) It seems that fields get referred to in various places as
>> fields
>> and attributes in the API. Is there any logic to this. That is
>> to
>> say, where should I use the word "field", and where should I use
>> the
>> word "attribute"?
>> Thanks
>> Chris
>> This message contains information, which is confidential and may
>> be
>> subject to legal privilege. If you are not the intended
>> recipient,
>> you must not peruse, use, disseminate, distribute or copy this
>> message. If you have received this message in error, please
>> notify
>> us immediately (Phone 0800 665 463 or info at linz.govt.nz
>> <mailto:info at linz.govt.nz>) and destroy the original message.
>> LINZ
>> accepts no responsibility for changes to this email, or for any
>> attachments, after its transmission from LINZ. Thank You.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> <mailto:Qgis-developer at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
