[Qgis-developer] r.random.raster
Victor Olaya
volayaf at gmail.com
Tue Apr 30 03:39:16 PDT 2013
> * the analysis fails
There is a typo in the call, I just found out that it says "randon"
instead of "random". Easy to fix
> * apparently a v.voronoi is executed together with the desired r.random.raster
This is the test to see that GRASS is installed. It will not be
performed again once it has passed
> * the help is missing, and a 404 web page is shown instead.
It seems they moved the help docs in the GRASS website. I will try to
redirect it.
One note: this module might have some problems with the extent and
cellsize, since it takes no input layer, so no automatic extent can be
used. i will check it later today, and fix it if needeed
Thanks!
Victor
