[Qgis-developer] WFS Client skipping features?
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Thu Aug 1 04:21:50 PDT 2013
I'm not seeing this. My WFS is GeoServer 2.3.4. I've tried several layers
and they're all showing the right feature count.
Are you certain it's the client that's skipping?
Jonathan
On 31 July 2013 18:27, Giovanni Manghi <giovanni.manghi at faunalia.pt> wrote:
> > I am testing QGIS desktop WFS client against a QGIS WFS server and see
> > that the client is skipping features - quite a lot in fact.
> > The server part seems to be fine as I can get all features to display
> > when using FME viewer as a client.
> > Do others have similar issues? Are there open bugs on the WFS client
> > regarding this? Any tips what I can do? Any hidden settings for limiting
> > the number of features?
> I had files a ticket about a similar issue
> http://hub.qgis.org/issues/8287
> is the same issue or another one?
> cheers!
> Qgis-developer mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130801/4ae895fd/attachment.html>
