[Qgis-developer] update plugin to QGIS 2.0
Matthias Kuhn
matthias.kuhn at gmx.ch
Fri Aug 2 06:22:23 PDT 2013
On Fre 02 Aug 2013 15:13:04 CEST, Etienne Tourigny wrote:
> On Fri, Aug 2, 2013 at 9:37 AM, Matthias Kuhn <matthias.kuhn at gmx.ch> wrote:
>> Hi
>> On Fre 02 Aug 2013 13:50:08 CEST, Etienne Tourigny wrote:
>>> for each band, if the point is outside of the raster extent or is
>>> nodata, the value will be a null QVariant (i.e. QVariant()) which in
>>> python is None.
>> It will be a QPyNullVariant so doing
>> value = QPyNullVariant( int )
>> if not value:
>> print 'Is NULL'
>> else:
>> print 'Is not NULL'
>> if value is None:
>> print 'Is None'
>> else:
>> print 'Is NOT None'
>> will print:
>> Is NULL
>> Is NOT None
> Hi,
> I was not referring to the value of QPyNullVariant( int ), but the
> value that results() would return in the case of nodata (which is
> QVariant() in the c++ code)
> unless mistaken, that would be converted to None by Sip - or am I wrong?
The SIP API v2 for QVariant defines:
An Invalid QVariant will be represented as None
A Null QVariant will be represented as QPyNullVariant [1]
Except for feature attributes (e.g. for a vectorlayer: feature['attr'])
which is patched by QGIS to become None in case of a Null value.
Matthias
[1]
http://pyqt.sourceforge.net/Docs/PyQt4/python_v3.html#qvariant
>> Sorry for the smart-arsing ;)
>> -- Matthias
>>> cheers
>>> Etienne
>>> On Fri, Aug 2, 2013 at 7:13 AM, Otto Dassau <dassau at gbd-consult.de> wrote:
>>>> Hi,
>>>> thanks for your hints, I think I am on the right track now. I had a look at
>>>> the value tool plugin and tried to adapt the method accordingly:
>>>> def sampleRaster20(self, layer, x, y):
>>>> #success, data = layer.dataProvider().identify(QgsPoint(x,y))
>>>> success, data = layer.dataProvider().identify(QgsPoint(x,y),QgsRaster.IdentifyFormatValue).results()
>>>> for band, value in data.items():
>>>> return value
>>>> But now I get another error message
>>>> File
>>>> "/home/dassau/.qgis2/python/plugins/weibullanalyse/weibullanalysedialog.py",
>>>> line 448, in printValue self.showValues() File
>>>> line 454, in showValues self.plot() File
>>>> line 526, in plot w = float(self.sampleRaster(self.InRastW.currentText(),
>>>> self.xCoord, self.yCoord))/10 File
>>>> line 300, in sampleRaster return self.sampleRaster20(layer, x, y) File
>>>> line 285, in sampleRaster20 success, data =
>>>> layer.dataProvider().identify(QgsPoint(x,y), QgsRaster.IdentifyFormatValue
>>>> ).results() ValueError: need more than 1 value to unpack
>>>> Do you have an idea for this, too?
>>>> Thanks
>>>> Otto
>>>> Am Thu, 1 Aug 2013 16:00:08 -0300
>>>> schrieb Etienne Tourigny <etourigny.dev at gmail.com>:
>>>>> Have a look at the source of the value tool plugin, it calls the identify()
>>>>> method and has been updated to 2.0 api.
>>>>> Etienne
>>>>> On Thu, Aug 1, 2013 at 1:58 PM, Otto Dassau <dassau at gbd-consult.de> wrote:
>>>>>> Hi,
>>>>>> I want to update a plugin from 1.8 to QGIS 2.0 and it throws following
>>>>>> error:
>>>>>> Traceback (most recent call last):
>>>>>> File
>>>>>> line 447, in printValue self.showValues() File
>>>>>> line 453, in showValues self.plot() File
>>>>>> line 514, in plot w = float(self.sampleRaster(self.InRastW.currentText(),
>>>>>> line 299, in sampleRaster return self.sampleRaster20(layer, x, y) File
>>>>>> line 284, in sampleRaster20 success, data =
>>>>>> TypeError:
>>>>>> QgsRasterDataProvider.identify(QgsPoint, QgsRaster.IdentifyFormat,
>>>>>> QgsRectangle theExtent=QgsRectangle(), int theWidth=0, int theHeight=0):
>>>>>> not enough arguments
>>>>>> I found at
>>>>>> http://hub.qgis.org/wiki/quantum-gis/API_changes_for_version_20 the
>>>>>> section QgsRasterDataProvider which should fit. And the Method, where I
>>>>>> assume the error occurs should be this
>>>>>> # get value at mouse position QGIS <= 1.8 (working for 1.8)
>>>>>> def sampleRaster18(self, layer, x, y):
>>>>>> success, data = layer.identify(QgsPoint(x,y))
>>>>>> return value
>>>>>> now what I tried but doesn't work (see error above)
>>>>>> # get value at mouse position QGIS >= 2.0 (not working yet :()
>>>>>> return value
>>>>>> my problem is, that I don't understand how to implement in sampleRaster20
>>>>>> the new method from the API_changes_for_version_20 website which says:
>>>>>> QMap<int, QVariant> identify( const QgsPoint & thePoint, IdentifyFormat
>>>>>> theFormat, const QgsRectangle &theExtent = QgsRectangle(), int theWidth =
>>>>>> 0, int theHeight = 0 )
>>>>>> can anybody help?
>>>>>> Thanks
>>>>>> Otto
>>>>>> _______________________________________________
>>>>>> Qgis-developer mailing list
>>>>>> Qgis-developer at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Geoinformatik Büro Dassau - http://www.gbd-consult.de
>>>> FOSSGIS consulting , training , support and analysis
>>>> Ackerstrasse 144c , D - 40233 Düsseldorf , Germany
>>>> Tel: +49-(0)211-47468178 , Mobil: +49-(0)171-4687540
>>>> Community Advisor - QGIS Project Steering Committee
