[Qgis-developer] Bug 7941 : workaround ?
Hien TRAN-QUANG
hien.tranquang at gmail.com
Fri Aug 2 06:32:50 PDT 2013
Hello,
Can you check that you have a file named ntf_r93.gsb in the
OSgeo4W/share/proj folder ? That file is a datum shift grid provided by
french IGN and is called by the "+nadgrids=ntf_r93.gsb" parameter in the
proj.4 call.
Hien.
> ---------- Message transféré ----------
> From: "Benoît Laurent" <blaurent at heurisis.eu>
> To: QGIS Developer List <qgis-developer at lists.osgeo.org>
> Cc:
> Date: Fri, 02 Aug 2013 14:47:20 +0200
> Subject: [Qgis-developer] Bug 7941 : workaround ?
> Hello,
> I am facing bug 7941 (http://hub.qgis.org/issues/**7941<http://hub.qgis.org/issues/7941>)
> which has not been corrected yet.
> I have many shapefiles in Lambert 93 and a raster file (.tif) in Lambert I
> which I would fit together. Because of the bug, I can't. Is there a
> workaround ? I tried to change the coordinates in the .tfw file but I does
> not work properly.
> Any help would be appreciated.
> Benoīt
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130802/eee8fc78/attachment.html>
