[Qgis-developer] Ubuntu QGIS Master package
Jeremy Palmer
JPalmer at linz.govt.nz
Mon Aug 5 14:34:08 PDT 2013
But the Ubuntu GIS unstable doesn't include master builds does it?
-----Original Message-----
From: Alex Mandel [mailto:tech_dev at wildintellect.com]
Sent: Monday, 5 August 2013 9:15 a.m.
To: Jeremy Palmer
Cc: qgis-developer at lists.osgeo.org; UbuntuGIS Users
Subject: Re: [Qgis-developer] Ubuntu QGIS Master package
On 08/04/2013 12:51 PM, Jeremy Palmer wrote:
> Any reason why the QGIS master ubuntu precise package still links against gdal 1.7? Would it not make sense for the master build to use 1.10 from the ubuntugis_unstable repo?
> This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
That's the way it's always been, qgis.org packages are built against stock ubuntu. It's a less complicated/cleaner approach. If you want newer deps you use ubuntugis. Generally mixing the 2 repos does not play nice.
It should actually be possible to setup a launchpad recipe to rebuild master in ubuntugis-testing or some other ppa and it is quite easy to recompile master oneself too.
Thanks,
Alex
