[Qgis-developer] Force QGIS to use a different version of Python in Snow Leopard
William Kyngesburye
woklist at kyngchaos.com
Tue Aug 6 06:41:45 PDT 2013
You can't. QGIS includes its own python interpreter and links directly to the Python framework. This ties it to a specific version and distribution (ie system Python 2.6). You either need to compile your own QGIS to use the other python, or install scipy for the system python.
I'm working on updating my Scipy distribution if you can wait, I just got distracted by the fortran requirement.
On Aug 6, 2013, at 5:07 AM, Jorge Arevalo wrote:
> Hello,
> I'm using QGIS 1.8.0 for Snow Leopard, downloaded from KingChaos wiki
> (http://www.kyngchaos.com/software/qgis). Once I open QGIS plugin
> console, I can see QGIS is using Snow Leopard's default Python
> (2.6.1).
> At the same time, I've installed Python 2.7.5 and some packages I
> need, like numpy or scipy. Specifically, I need scipy 0.12. If I open
> python from a command line, version 2.7.5 is used.
> The problem is I need that QGIS also uses Python 2.7, to detect scipy
> 0.12 (default system Python, 2.6.1, uses scipy 0.11.0). Default Python
> is installed at /Library/Python, but my manually installed Python 2.7
> is installed at /Library/Frameworks/Python.Framework. I guess QGIS
> looks for default Python first.
> How could I "force" QGIS to use my own Python version? Do I have to
> compile it by myself, instead of using KingChaos packages? I was
> thinking in something easier, like modifying Python path just for
> QGIS.
> Best regards,
> Jorge Arévalo
> http://geomati.co
> Qgis-developer mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
