[Qgis-developer] Renaming SEXTANTE
Nathan Woodrow
madmanwoo at gmail.com
Sun Aug 11 16:15:43 PDT 2013
Showing SEXTANTE, GDAL Tools, fTools in the menu is the implementation
model leaking into the UI. The users don't care how it's implemented as
long as it works.
- Nathan
On Mon, Aug 12, 2013 at 9:04 AM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> On Mon, Aug 12, 2013 at 12:14 AM, Alex Mandel <tech_dev at wildintellect.com>wrote:
>> So is the proposal to change Analysis to Processing?
>> I don't think there's a reason to remove the SEXTANTE branding as
>> SEXTANTE does exist outside a QGIS context, ftools is another story
>> since that only exists in QGIS. I'm split on GDAL Tools, since it is
>> good to make sure users know what underlying tool is being used (ie in
>> the event they want to use the command line).
>> As for the Vector, Raster, etc menus... it's expected that over time
>> plugins will sort themselves into those menus in order to add
>> organization and make it more obvious what a tool does. It also makes
>> the generic plugins section smaller so that you don't have to wade
>> through 100 plugins to find the one you want.
>> The same applies for Analysis or Processing, I expect other analysis and
>> processing tools to exist that are not SEXTANTE but end up on the list,
>> in which case being able to tell it apart from what's there remains
>> important.
>> To me this is a UI question, not a core vs. non-core/c++ vs. python
>> question. ie: How do we organize and arrange menus to maximize discovery
>> of tools and ease workflow (fewer clicks or faster nav to the correct
>> tool).
>> Analysis or Processing are both fine to me so +0 or maybe Advanced ....?
> The issue is more that in plugin manager you see all these strangely named
> things which don't match their corresponding user interface components...
> Also users of the API have to deal with these naming ideosychrasies - it
> would be much nicer to do geoprocessing.* than sextante.*
> Regards
> Tim
>> Thanks,
>> Alex
>> On 08/10/2013 10:53 PM, Saber Razmjooei wrote:
>> > +1 for changing name.
>> > I like GRASS menus, it has all the analytical modules under vector and
>> > raster menu. Can similar thing be done with SEXTANTE?
>> > Cheers
>> > Saber
>> > On 2013-08-10 12:23, Alexander Bruy wrote:
>> >> +1 from me to renaming.
>> >> Maybe we can use "Processing" or "GeoProcessing" as new name.
>> >> 2013/8/10 Nathan Woodrow <madmanwoo at gmail.com>:
>> >>> +1 from me too.
>> >>> Personally I find the core plugin concept unnecessary. If it's core it
>> >>> shouldn't be a plugin and should just be part of the main program.
>> >>> It can
>> >>> still be Python that is fine however users shouldn't have to turn
>> >>> them on
>> >>> and off they should just be there and be transparent.
>> >>> IMO we should aim to kill of all C++ core plugins in 2.1 and make
>> >>> them core
>> >>> features.Things like the geometry checking, spatial join,
>> georeferencer
>> >>> should all be core features and have C++ and Python APIs that the
>> >>> user can
>> >>> use.
>> >>> - Nathan
>> > This email and any files transmitted with it are confidential and
>> > intended solely for the use of the individual or entity to whom they are
>> > addressed. If you have received this email in error please notify the
>> > system manager. This message contains confidential information and is
>> > intended only for the individual named. If you are not the named
>> > addressee you should not disseminate, distribute or copy this e-mail.
>> > Please notify the sender immediately by e-mail if you have received this
>> > e-mail by mistake and delete this e-mail from your system. If you are
>> > not the intended recipient you are notified that disclosing, copying,
>> > distributing or taking any action in reliance on the contents of this
>> > information is strictly prohibited.
>> > Whilst reasonable care has been taken to avoid virus transmission, no
>> > responsibility for viruses is taken and it is your responsibility to
>> > carry out such checks as you feel appropriate.
>> > Saber Razmjooei and Peter Wells trading as Lutra Consulting.
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130812/3e0a819b/attachment.html>
