[Qgis-developer] Renaming SEXTANTE
Nathan Woodrow madmanwoo at gmail.com
Mon Aug 12 01:13:36 PDT 2013
If you are loading them by default it doesn't make sense to keep them as a
plugins better to just make them core. It doesn't really matter at the
moment for 2.0 anyway but I'll chat about it more at the HF
 On 12/08/2013 6:02 PM, "Tim Sutton" <lists at linfiniti.com> wrote:
> Hi
> On Mon, Aug 12, 2013 at 9:32 AM, Nathan Woodrow <madmanwoo at gmail.com>wrote:
>> On Mon, Aug 12, 2013 at 5:13 PM, Marco Hugentobler <
>> marco.hugentobler at sourcepole.ch> wrote:
>>> Plugins are a sophisticated way of keeping things lean and separated.
>> I have no issue with none core plugins, in fact that is something I
>> always promote as a powerful feature. Core however plugins are a different
>> story. While it makes sense to you and I it doesn't make sense to a normal
>> user. Core plugins, while a feature, in fact make the program look
>> incomplete or patchy.  Some of the main problems with core plugins are:
>> they don't have a Python C++ API, functions in them are separated by wall,
>> users have to enable them in order to use them.
>> Lets take a few examples:  A question the other day on IRC was "can I
>> create a heatmap with pyqgis" No is the answer which is confusing because
>> the heatmap plugin is a core feature so why not have it as part of the API?
>>  The topology checker is another example of the features it has should be
>> part of the core package and just baked in. This would allow tighter
>> integration into the drawing tools and other core features. Can you imagine
>> if snapping was a core plugin? or the composer?
>> I do see the core plugin idea useful as a staging area for things we are
>> not sure fully about just yet or still have issues.
> I think this should be simple to address - maintain them as plugins but
> load them automatically and transparently to the user. We could even have a
> new class oc core plugins that do this and explcitly bypass the plugin
> manager ui because they are always 'just on'.
> Regards
> Tim
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130812/cc143576/attachment.html>
