[Qgis-developer] [gdal-dev] QGIS hanging when opening a FileGDB on 64 bit Linux
Even Rouault
even.rouault at mines-paris.org
Mon Aug 12 16:29:21 PDT 2013
Le lundi 12 août 2013 22:12:11, Jeremy Palmer a écrit :
> Further to this I see that when you open a FIleGDB in QGIS 3 OGROpen calls
> made to the same database before any OGR_DS_Destroy calls are made. These
> open calls occur during the layer selection dialog, the OGR provider
> construction, and the initialisation of the QgsOgrFeatureIterator.
> I'm guessing the fix for this should really be done at the Esri library
> level, but because we have no control over this maybe something can be
> done in the OGR library to reuse FileGDBAPI Geodatabase handles?
Jeremy,
I do think this is exactly the issue of
http://forums.arcgis.com/threads/76527-CloseDatabase-hanging-on-64-bit-Lin ux-
when-same-File-Geodatabase-opened-twice
At least I reproduced it on my own PC. I've implemented a workaround in GDAL
trunk for that issue that implements ref-counting of the FileGDBAPI Geodabase
handle at OGR side : http://trac.osgeo.org/gdal/changeset/26307.
Even
> Cheers,
> Jeremy
> -----Original Message-----
> From: Jeremy Palmer
> Sent: Sunday, 11 August 2013 9:08 a.m.
> To: qgis-developer at lists.osgeo.org
> Subject: QGIS hanging when opening a FileGDB on 64 bit Linux
> Hi QGIS devs!
> Since the latest round of code changes (maybe over the last 2 months) I can
> no longer open Esri FileGDB in QGIS. I can read the database and QGIS
> prompts me from the FileGDB layers to add to the map, but when I select
> the layer from this dialog QGIS just hangs. I did some debugging and it
> seems to hang on the OGR_DS_Destroy call within
> QgsOgrFeatureIterator::close(). Does anyone else have this problem?
> I'm running FileGDB SDK 1.3 and Ubuntu 12.04 64bit with QGIS master. I've
> tested this with the OSGeo4W win32 qgis-dev package and I don't get the
> problem.
> Could this be related to this issue:
> ux-when-same-File-Geodatabase-opened-twice
> Cheers,
> Jeremy
> This message contains information, which is confidential and may be subject
> to legal privilege. If you are not the intended recipient, you must not
> peruse, use, disseminate, distribute or copy this message. If you have
> received this message in error, please notify us immediately (Phone 0800
> 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Geospatial professional services
http://even.rouault.free.fr/services.html
