[Qgis-developer] Problems to restart QGIS
Matthias Kuhn matthias.kuhn at gmx.ch
Sun Aug 18 21:45:41 PDT 2013
Hi Kari,
Looks to me like your qgis executable is trying to run with a library
(libqgis_*.so) it is not built against (maybe the master executable is
trying to run with a 1.8 library). You probably have compiled qgis
yourself?
You can have a look here for setting the library path
http://hub.qgis.org/issues/5859
And you can also rebuild / reinstall your qgis to make sure you have
matching library and executable.
Cheers
On Thu 15 Aug 2013 08:50:18 PM CEST, Kari Salovaara wrote:
> Hi,
> I was testing (I'm translator for Finnish language) Print Composer, I
> closed Print Composer using Quit, whole program was closed !
> Then I wanted to restart QGIS, see below with result;
> ./apps/bin # ./qgis
> ./qgis: symbol lookup error: ./qgis: undefined symbol:
> _ZN13QwtLegendItem16staticMetaObjectE
> I cannot get QGIS runnning anymore at all (probably by deleting whole
> ./qgis2 directory but there seems to be none file dated to current date)
> QGIS-master version is for date 8.8.2013 UTC 14:10
> Environment uptodate openSuse 12.1
> qgsversion.h
> 96/96                100%
> #define QGSVERSION "0878fca"
> #define QGS_GIT_REMOTE_URL "git://github.com/qgis/Quantum-GIS.git"
> I've also 1.8.0 running in same machine and if I close Print Composer
> it doesn't close main program ! Environment there is:
> QGIS version
> 1.8.0-Lisboa
> QGIS code revision
> exported
> Compiled against Qt
> 4.7.4
> Running against Qt
> 4.7.4
> Compiled against GDAL/OGR
> 1.10.0
> Running against GDAL/OGR
> 1.10.0
> GEOS Version
> 3.3.8
> PostgreSQL Client Version
> 9.1.9
> SpatiaLite Version
> 4.1.1
> QWT Version
> 5.2.2
> Can You give any commendations before I do some cleaning and total
> recompilation and reinstall ?
> Cheers,
> Kari
> Kari Salovaara
> Hanko, Finland
> "Volunteers do not necessarily have the time; they just have the heart." ~Elizabeth Andrew
> Qgis-developer mailing list
