[Qgis-developer] FIX BUG #8473 Cannot rename layers in composer legend
rldhont rldhont at gmail.com
Tue Aug 20 05:21:18 PDT 2013
Hi all,
The bug 'Cannot rename layers in composer legend' has been opened because :
1) users cannot update rasterlayer label
2) users cannot update vector layer simple symbol label
I finalized the 2 points with the pull request 824
https://github.com/qgis/Quantum-GIS/pull/824
If it is good for you I can merge it.
René-Luc D'Hont
Le 19/08/2013 22:00, Etienne Tourigny a écrit :
> you should create a pull request
> On Mon, Aug 19, 2013 at 9:31 AM, rldhont <rldhont at gmail.com
> <mailto:rldhont at gmail.com>> wrote:
>     Hi all,
>     The bug 8473 'Cannot rename layers in composer legend' is marked
>     as Blocker.
>     http://hub.qgis.org/issues/8473
>     I have created a branch to supply a patch :
>     https://github.com/rldhont/Quantum-GIS/tree/8473
>     You can see the diff :
>     https://github.com/rldhont/Quantum-GIS/commit/f3edd5445520030c75880109677fb1751cc9d7e1
>     If you validate this patch I can push it.
>     Regards,
>     René-Luc D'Hont
>     3Liz
>     _______________________________________________
>     Qgis-developer mailing list
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130820/b6f49a58/attachment.html>
