[Qgis-developer] [qgis webclient] malformed header from script. Bad header=credentials for dbname
Andreas Neumann
a.neumann at carto.net
Sun Aug 25 07:24:25 PDT 2013
Hi Otto,
This is most likely a QGIS project issue.
Perhaps you did not save the db connection credentials in the data
source? You should save both user and password in your project file.
Matthias Kuhn came up with a saver solution where one does not have to
store the credentials - but I can't find it now.
Andreas
On Sun, 25 Aug 2013 15:47:30 +0200, Otto Dassau wrote:
> Hi,
> I have some vector layers in a postgis2 database, provide them via
> QGIS
> server (ubuntu package from master) and visualize with QGIS
> webclient. In
> qgis-web-client-error.log I get following error
> "malformed header from script. Bad header=credentials for
> dbname='testdb':"
> I set up the qgs project file on my local PC and the error occurs,
> when I
> copy the file to the server, where postgis and QGIS server is
> installed.
> Thanks for any hints
> Otto
> Qgis-developer mailing list
