[Qgis-developer] mixed packages in qgis nightly build precise repository
Jürgen E. Fischer
jef at norbit.de
Wed Aug 28 03:38:14 PDT 2013
Hi Giovanni,
On Wed, 28. Aug 2013 at 10:10:48 +0100, Giovanni Manghi wrote:
> the situation is not fixed, today there are packages update to 26/08
> and others still from 19/08 build.
> Isn't this the disk space issue that we already had in the past?
No. It's still the same diskspace issue. I just retired the squeeze build
(old debian stable). But it's a constant struggle to tidy up other stuff to
keep room for the builds...
### Mon Aug 26 16:00:02 PDT 2013: NIGHTLY BUILD FOR squeeze lucid lucid-ubuntugis precise precise-ubuntugis quantal quantal-ubuntugis raring wheezy unstable STARTED
### Mon Aug 26 16:00:02 PDT 2013: UPDATE COWBUILDER
### Mon Aug 26 16:02:46 PDT 2013: COWBUILDER UPDATED
### Mon Aug 26 16:04:28 PDT 2013: UPDATING API DOCUMENTATION
### Mon Aug 26 16:04:32 PDT 2013: UPDATING API DOCUMENTATION FAILED 0
### Mon Aug 26 16:04:40 PDT 2013: BUILD 1.9.0+git20130826+80c9199~squeeze1 FOR i386
### Mon Aug 26 17:20:57 PDT 2013: BUILD FINISHED IN 1h16m17s
### Mon Aug 26 17:20:57 PDT 2013: BUILD 1.9.0+git20130826+80c9199~squeeze1 FOR amd64
### Mon Aug 26 18:28:01 PDT 2013: BUILD FINISHED IN 1h7m4s
### Mon Aug 26 18:28:08 PDT 2013: BUILD 1.9.0+git20130826+80c9199~lucid1 FOR i386
### Mon Aug 26 19:36:15 PDT 2013: BUILD FINISHED IN 1h8m7s
### Mon Aug 26 19:36:15 PDT 2013: BUILD 1.9.0+git20130826+80c9199~lucid1 FOR amd64
### Mon Aug 26 21:01:29 PDT 2013: BUILD FINISHED IN 1h25m14s
### Mon Aug 26 21:01:34 PDT 2013: BUILD 1.9.0+git20130826+80c9199~lucid-ubuntugis1 FOR i386
### Mon Aug 26 22:27:18 PDT 2013: BUILD FINISHED IN 1h25m44s
### Mon Aug 26 22:27:18 PDT 2013: BUILD 1.9.0+git20130826+80c9199~lucid-ubuntugis1 FOR amd64
### Tue Aug 27 00:04:11 PDT 2013: BUILD FINISHED IN 1h36m54s
### Tue Aug 27 00:04:21 PDT 2013: BUILD 1.9.0+git20130826+80c9199~precise1 FOR i386
### Tue Aug 27 03:49:18 PDT 2013: BUILD FINISHED IN 3h44m57s
### Tue Aug 27 03:49:18 PDT 2013: BUILD 1.9.0+git20130826+80c9199~precise1 FOR amd64
### Tue Aug 27 05:59:07 PDT 2013: BUILD FINISHED IN 2h9m49s
### Tue Aug 27 05:59:17 PDT 2013: BUILD 1.9.0+git20130826+80c9199~precise-ubuntugis1 FOR i386
### Tue Aug 27 07:59:46 PDT 2013: BUILD FINISHED IN 2h29s
### Tue Aug 27 07:59:46 PDT 2013: BUILD 1.9.0+git20130826+80c9199~precise-ubuntugis1 FOR amd64
cp: writing `debian/qgis-api-doc//usr/share/qgis/doc/api/classQgsComposerAttributeTable__coll__graph.png': No space left on device
cp: failed to extend `debian/qgis-api-doc//usr/share/qgis/doc/api/classQgsComposerAttributeTable__coll__graph.png': No space left on device
cp: writing `debian/qgis-api-doc//usr/share/qgis/doc/api/qgssingleboxscalebarstyle_8h__dep__incl.png': No space left on device
cp: failed to extend `debian/qgis-api-doc//usr/share/qgis/doc/api/qgssingleboxscalebarstyle_8h__dep__incl.png': No space left on device
cp: writing `debian/qgis-api-doc//usr/share/qgis/doc/api/parse_8h__incl.png': No space left on device
cp: failed to extend `debian/qgis-api-doc//usr/share/qgis/doc/api/parse_8h__incl.png': No space left on device
cp: writing `debian/qgis-api-doc//usr/share/qgis/doc/api/classQgsNewVectorLayerDialog.html': No space left on device
### Tue Aug 27 11:14:00 PDT 2013: BUILD ERROR 1.9.0+git20130826+80c9199~precise-ubuntugis1 FOR amd64 AFTER 3h14m14s
### Tue Aug 27 11:14:05 PDT 2013: EXPECTED MERGE changes ../builds/qgis_1.9.0+git20130826+80c9199~precise-ubuntugis1_i386.changes MISSING
### Tue Aug 27 11:14:14 PDT 2013: BUILD 1.9.0+git20130826+80c9199~quantal1 FOR i386
### Tue Aug 27 13:04:05 PDT 2013: BUILD FINISHED IN 1h49m51s
### Tue Aug 27 13:04:05 PDT 2013: BUILD 1.9.0+git20130826+80c9199~quantal1 FOR amd64
### Tue Aug 27 14:37:33 PDT 2013: BUILD FINISHED IN 1h33m28s
### Tue Aug 27 14:37:36 PDT 2013: BUILD 1.9.0+git20130826+80c9199~quantal-ubuntugis1 FOR i386
### Tue Aug 27 16:06:44 PDT 2013: BUILD FINISHED IN 1h29m8s
### Tue Aug 27 16:06:44 PDT 2013: BUILD 1.9.0+git20130826+80c9199~quantal-ubuntugis1 FOR amd64
### Tue Aug 27 17:42:21 PDT 2013: BUILD FINISHED IN 1h35m37s
### Tue Aug 27 17:42:23 PDT 2013: BUILD 1.9.0+git20130826+80c9199~raring1 FOR i386
### Tue Aug 27 18:47:27 PDT 2013: BUILD FINISHED IN 1h5m4s
### Tue Aug 27 18:47:27 PDT 2013: BUILD 1.9.0+git20130826+80c9199~raring1 FOR amd64
### Tue Aug 27 19:51:05 PDT 2013: BUILD FINISHED IN 1h3m38s
### Tue Aug 27 19:51:07 PDT 2013: BUILD 1.9.0+git20130826+80c9199~wheezy1 FOR i386
### Tue Aug 27 21:05:39 PDT 2013: BUILD FINISHED IN 1h14m32s
### Tue Aug 27 21:05:39 PDT 2013: BUILD 1.9.0+git20130826+80c9199~wheezy1 FOR amd64
cp: writing `debian/qgis-api-doc//usr/share/qgis/doc/api/qgscontrastenhancement_8h_source.html': No space left on device
cp: failed to extend `debian/qgis-api-doc//usr/share/qgis/doc/api/qgscontrastenhancement_8h_source.html': No space left on device
cp: writing `debian/qgis-api-doc//usr/share/qgis/doc/api/inherit_graph_93.png': No space left on device
cp: failed to extend `debian/qgis-api-doc//usr/share/qgis/doc/api/inherit_graph_93.png': No space left on device
cp: writing `debian/qgis-api-doc//usr/share/qgis/doc/api/classQgsNetworkAccessManager-members.html': No space left on device
cp: failed to extend `debian/qgis-api-doc//usr/share/qgis/doc/api/classQgsNetworkAccessManager-members.html': No space left on device
cp: writing `debian/qgis-api-doc//usr/share/qgis/doc/api/qgsidwinterpolator_8cpp__incl.md5': No space left on device
cp: failed to extend `debian/qgis-api-doc//usr/share/qgis/doc/api/qgsidwinterpolator_8cpp__incl.md5': No space left on device
cp: writing `debian/qgis-api-doc//usr/share/qgis/doc/api/qgsgpsconnectionregistry_8h__incl.png': No space left on device
cp: failed to extend `debian/qgis-api-doc//usr/share/qgis/doc/api/qgsgpsconnectionregistry_8h__incl.png': No space left on device
cp: writing `debian/qgis-api-doc//usr/share/qgis/doc/api/qgsapplication_8cpp__incl.map': No space left on device
cp: failed to extend `debian/qgis-api-doc//usr/share/qgis/doc/api/qgsapplication_8cpp__incl.map': No space left on device
### Tue Aug 27 22:16:47 PDT 2013: BUILD ERROR 1.9.0+git20130826+80c9199~wheezy1 FOR amd64 AFTER 1h11m8s
### Tue Aug 27 22:16:49 PDT 2013: EXPECTED MERGE changes ../builds/qgis_1.9.0+git20130826+80c9199~wheezy1_i386.changes MISSING
### Tue Aug 27 22:17:02 PDT 2013: BUILD 1.9.0+git20130826+80c9199~unstable1 FOR i386
### Tue Aug 27 23:41:41 PDT 2013: BUILD FINISHED IN 1h24m39s
### Tue Aug 27 23:41:41 PDT 2013: BUILD 1.9.0+git20130826+80c9199~unstable1 FOR amd64
### Wed Aug 28 01:27:30 PDT 2013: BUILD FINISHED IN 1h45m49s
### Wed Aug 28 01:27:39 PDT 2013: BUILDS ENDED
### Wed Aug 28 01:27:39 PDT 2013: UPDATING REPOSITORY
### Wed Aug 28 01:35:35 PDT 2013: REPOSITORY UPDATED AFTER 7m56s
### Wed Aug 28 01:35:35 PDT 2013: NIGHTLY BUILD ENDED AFTER 1d9h35m34s
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS PSC member (RM) IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
