[Qgis-developer] Newbie question re building qgis
h
hdixon at bigpond.net.au
Tue Dec 10 02:16:36 PST 2013
I am running linux - Mageia 3 (intel x86-64) and want to run qgis 2+.
The mageia repo only has 1.x.
I have had problems running qgis as I installed 1.x and did a
compile /build as per the github install instructions. I believe I
have now cleaned out the 1.x and only have the current source on my
system.
I am able to build / compile / install qgis without problem, and the
application starts, however I have problems loading the "open layers"
and gearthview plugins. I get:
An error has occured while executing Python code:
File
"/home//.qgis2/python/plugins/openlayers_plugin/openlayers_plugin.py", line 50, in addLayer
self.__plugin.addLayer(self)
File
"/home//.qgis2/python/plugins/openlayers_plugin/openlayers_plugin.py", line 202, in addLayer
self.__setMapSrsGoogle()
File
"/home//.qgis2/python/plugins/openlayers_plugin/openlayers_plugin.py", line 253, in __setMapSrsGoogle
mapCanvas.mapRenderer().setProjectionsEnabled(True)
TypeError: C++ type 'const QgsMapLayer*' is not supported as type
Python version:
2.7.5 (default, Aug 12 2013, 12:12:07)
[GCC 4.7.2]
QGIS version:
2.1.0-Master Master, c610f37
Can someone please advise. I suspect I am using an old version of the
plugin and that either I have not rebuilt it, or I am loading it from
the wrong location.
Should I have reset the path for plugins to work with the development
system? (please point me to the bit of the manual I should have read if
this is the case!)
Do I need to do something other than "make" to build all the plugins?
Have I left something floating around from 1.x?
Any help gratefully appreciated!
Hugh
