[Qgis-developer] Vincenty's Formulae
Jorge Tornero - Listas
jtorlistas at gmail.com
Wed Dec 11 23:36:27 PST 2013
Dear all.
I'm currently working on a python plugin for QGIS which deploys points
along lines on a given distance basis. The lines, say transects, are
created placing an initial point and then providing a bearing for the
line. Then, n stations/smapling points are deployed in its place.
I'm using Vincenty's Formula to get the coordinates for the points. So
far, I've found an python implementation for this, but I haven't been
able to know under which license is released the code, as far as I have
found the code in a forum
(https://isis.astrogeology.usgs.gov/IsisSupport/index.php?topic=408.0)
but the link provided in the message for the original code can't be
followed.
As far as I know, in QGIS API there is no direct Vincenty's formula to
compute in this way (point, azimuth/bearing + distance to destiny), and
I want to make the plugin dependence-free as possible, so my questions are:
1) Do you know if, in QGIS API, is there and usable implementation of
Vincenty's direct formula?
2) Is it fair to copy the code posted in the forum as is? (auto-answer:
I don't think so....)
3) In this case, how should it be credited in my code?
4) Should be better to reimplement it in a class apart and release it
under GPL3? is this possible?
By the way, the plugin name will be Transectizer... any better ideas?
Best regards,
Jorge Tornero
Instituto Español de Oceanografía
Centro Oceanográfico de Cádiz
Cádiz, Spain
http://www.ieo.es
http://imasdemase.com
