[Qgis-developer] Vincenty's Formulae
Jorge Tornero - Listas jtorlistas at gmail.com
Thu Dec 12 04:44:51 PST 2013
Hi, Martin, thank you for your answer.
Well, the problem is that QgsDistanceArea class provides a function to
(that's what I think due to my limitations in C++) calculate the
distance an bearing between two points (start-end points). This is what
INVERSE Vicenty Formula does, and I think thatthat's the formula
implemented in QgsDistanceArea with its method computeDistanceBearing.
This metod, as stated in the API documentation,calculates distance from
two points on ellipsoid based on inverse Vincenty's formulae: given a
departure point P, and destination point P2, it yields the distance
between the two points and the bearing from P to P2 as well as from P2 to P.
But I want to perform another calculation: Calculate the destination
point P2 given an departure point P, a bearing B and a distance D.
That's what direct Vincenty Formulae performs and it's what I'm looking
for :(
Thank you very much,
Jorge Tornero
El 12/12/13 13:24, Martin Dobias escribió:
> On Thu, Dec 12, 2013 at 2:36 PM, Jorge Tornero - Listas
> <jtorlistas at gmail.com> wrote:
>> Dear all.
>> I'm currently working on a python plugin for QGIS which deploys points along
>> lines on a given distance basis. The lines, say transects, are created
>> placing an initial point and then providing a bearing for the line. Then, n
>> stations/smapling points are deployed in its place.
>> I'm using Vincenty's Formula to get the coordinates for the points. So far,
>> I've found an python implementation for this, but I haven't been able to
>> know under which license is released the code, as far as I have found the
>> code in a forum
>> (https://isis.astrogeology.usgs.gov/IsisSupport/index.php?topic=408.0) but
>> the link provided in the message for the original code can't be followed.
>> As far as I know, in QGIS API there is no direct Vincenty's formula to
>> compute in this way (point, azimuth/bearing + distance to destiny), and I
>> want to make the plugin dependence-free as possible, so my questions are:
>> 1) Do you know if, in QGIS API, is there and usable implementation of
>> Vincenty's direct formula?
> Hi Jorge
> What about QgsDistanceArea class? It does the calculation of distance
> / bearing on ellipsoid.
> Regards
> Martin
