[Qgis-developer] 1:n relation style
Andreas Neumann a.neumann at carto.net
Fri Dec 20 01:53:00 PST 2013
Well - it is not so easy to use 1:n relations in styling - not as easy
as with the 1:1 joins. At least not from the "1" side. What would you
use (min, max, mean, median, other aggregates)
Or are you talking about the "n" side - where there is a clear relation
just to one element that could be used?
Andreas
Am 19.12.2013 22:03, schrieb Matthias Kuhn:
> Hi Matteo,
> This is unfortunately not possible with the relations feature.
> Nevertheless, there is the "Join" feature in the layer properties,
> which enables you to do what you want.
> I hope to be able to integrate this feature into the realtions as well,
> so we will have a more integrated solution.
> Regards,
> Matthias
> On Don 19 Dez 2013 19:35:22 CET, matteo wrote:
>> Hi guys,
>> I'm testing the new 1:n relation (really awesome guys!). Simple
>> question: is it possible to categorize or work with the graduated
>> simbology or whatever of the shapefile, but with the attributes of the
>> related table?
>> Cheers
>> Matteo
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
