[Qgis-developer] problem with forms and python init function
Luca Lanteri
mescal72 at gmail.com
Fri Dec 20 03:03:44 PST 2013
Hi to all,
I'm a newbie with pyqgis so apologize me for the trivial question. I'm
trying to create a forms using QT and to add some intelligence into it
using the "python Init function", present in the Layer properties ->
field menu. I want to update the data in combo2 on the base of the
combo1 choosed value, but I encountered some problem, probably due to
my lack of knowled of QGIS API. This is my first problems:
I try to read some data from a layer using this code [1]. If the layer
is a geometry layer all works fine but if I try to read the data from
a table (without geom coloumn) i cant read the attributes. Both object
are QgsVectorLayer so I though that I can use the same methods. In
order to resolve this problem i just addes a geom coloum to my table
but it's just a ploy.
The second, and the very real problem, is that when I try to update
the the value using the
curLayer.changeAttributeValue() method some strange beaviours occours.
- If i try to commit changes from the code (using
curLayer.commitChanges() ), and I'm in the table form view, Qgis
crash.
- when I try to commit changes use the toogle editing mode button, and
I'm in the table form view, all my changes are lost.
I'm just in the form view, changes are lost alternatively once on two
saving operation.
I don't understand if this is a problem of my code or a qgis bug.
Any hint ?
I hope to have described the problem clearly.
thank in advance
Luca
[1]
alegend = iface.legendInterface()
allLayers=alegend.layers()
for i in allLayers:
if i.name()=='mytab':
aLayer=i
lista=[]
rsTipo=[]
for i in afeature:
a=i.attributes()
l1=i.attributes()[0]
l2=i.attributes()[1]
l3=i.attributes()[2]
l4=i.attributes()[3]
alist=[l1,l2,l3,l4]
rsTipo.append(alist)
