[Qgis-developer] qgisserver problem
Richard Duivenvoorde rdmailings at duif.net
Fri Dec 20 06:32:22 PST 2013
Fixed by pulling a fresh master...
On 19-12-13 20:59, Richard Duivenvoorde wrote:
> Compiled QGIS testing (12 dec) on a clean debian wheezy box
> copied qgis_mapserv.fcgi into /usr/lib/cgi-bin and created a vanilla qgs
> project file
> but while getting a capabilities response, I'm not able to receive map
> images...
> some other problems:
> - if I start a epsg:28992 project, then the latlon capabilites contain
> those crs coordinates in the LATLONboundingbox in capabilities
> - if I start a epsg:4326 (latlon) project, then both the latlonbbox and
> the crsbbox contain latlon coords???
> also some problems with the 'crs selection' in ows properties of project
> dialog.
> When I try to load the layer via a remote QGIS wms connection, I see the
> error:
> - 'Cannot calculate extent', Raster layer is not valid ...
> When I try to load an image via a local browser I see this error:
> invalidCRS: could not create output CRS
> Am I doing something wrong, of does the server need more info?
> Docs I found:
> http://www.qgis.org/en/docs/user_manual/working_with_ogc/ogc_server_support.html?highlight=server
> Capabilities requests you can try:
> http://qgis.webmapper.nl/cgi-bin/qgis_mapserv.fcgi?request=getCapabilities&map=nl.qgs
> http://qgis.webmapper.nl/cgi-bin/qgis_mapserv.fcgi?request=getCapabilities&map=nl2.qgs
> http://qgis.webmapper.nl/cgi-bin/qgis_mapserv.fcgi?request=getCapabilities&map=world.qgs
> anybody can help me?
> Regards,
> Qgis-developer mailing list
