[Qgis-developer] Qgis2threejs suggestions...
Minoru Akagi akaginch at gmail.com
Tue Dec 31 02:32:59 PST 2013
Hi Roberto,
Thank you for your suggestions.
2013/12/31 Geo DrinX <geodrinx at gmail.com>:
> The only thing that I find to be improved is the fact that it opens a new
> web page, and that is opened in QGis an information panel on which (if any)
> choose the DEM layer.
> For me, the panel should be "confined" in a panel on "Settings", and instead
> the function must be called directly (and using the same web page)
> Sure, with this, everything would be (even more) immediate and amazing.
I will increase the number of items in the dialog. I have already
implemented multiple resolution output that has both detailed close
view and rough distant view, and would like to challenge vector data
output. I think it is good to provide an option to output simple one
by 1-click from the toolbar button so that user can preview easily. I
will also consider an option to open page in existing tab.
> Also I suggest to use a temporary directory inside the plugin directory, as
> in my GEarthView plugin.
I'll consider it. If you have some reasons that temporary directory
inside the plugin directory is better than system temporary directory,
please tell me.
Regards,
Minoru
