[Qgis-developer] OSM address search
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Tue Dec 31 04:36:22 PST 2013
> The implementation should be generic enough that we can add other data
>> sources.
> That would be very good. Ideally including the ability to use a WFS - then
organisations could use their already-extant WFS service to supplement (or
replace) OSM.
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131231/16520e22/attachment.html>
