[Qgis-developer] Installation using OSGEO4W 32 and 64 bit.
Randal Hale rjhale at northrivergeographic.com
Tue Dec 31 09:53:44 PST 2013
So I've tried this a couple of different ways but the end result is the
same. So I hope it's just me.
I downloaded the 32 and 64 bit installer of OSGEO4W and have done an
install (using each in two different attempts). Here are the steps and
the error messages (I think) I'm getting. At the end of this I have a
QGIS install with most of the GDAL menus missing (or at least that's
what I call them).
1. Download the installer.
2. Right click and run as administrator
3. Select Express install
4. Click Next twice and then I get an error (except the install these
packages to meet dependencies is checked).
avce00    (2.0.0-1)
     The AVCE00 commandline utilities for Arc/Info E00 conversion
     Required by: grass
curl    (7.3.1-1)
     The CURL HTTP/FTP library and commandline utility.
     Required by: gdal, netcdf
expat    (2.1.0-1)
     The Expat XML Parser library
     Required by: gdal, ogdi, gpsbabel
fftw    (3.3.3-1)
     Fast Fourier transformation library (Development)
     Required by: grass
freexl    (1.0.0e-1)
     The FreeXL library for accessing Excel (.xls) spreadsheet.
     Required by: gdal, spatialite
gdal-ecw    (1.10.1-4)
     ECW Raster Plugin for GDAL
     Required by: qgis-full
gdal-filegdb    (1.10.1-4)
     OGR FileGDB Driver
gdal-mrsid    (1.10.1-4)
     MrSID Raster Plugin for GDAL
gdal-oracle    (1.10.1-4)
     OGR OCI and GDAL GeoRaster Plugins for Oracle
gdal-python    (1.10.1-4)
     The GDAL/OGR Python Bindings and Scripts
     Required by: qgis
geos    (3.4.2-1)
     The GEOS geometry library
     Required by: gdal, spatialite, python-shapely, qgis-common
gpsbabel    (1.4.4-1)
     GPS file conversion plus transfer to/from GPS units
     Required by: grass, qgis
gs    (9.07-1)
     Ghostscript
     Required by: grass
gsl-libs    (1.15-1)
     GNU Scientific Library (GSL)
     Required by: qgis-common
hdf4    (4.2.9-1)
     The HDF4 library for reading and writing HDF4 format
     Required by: gdal
hdf5    (1.8.11-2)
     The HDF5 library for reading and writing HDF5 format
iconv    (1.14-1)
     Codepage translation Library
     Required by: gdal, grass, spatialite, freexl, qgis, qgis-common
libgeotiff    (1.4.0-1)
     The Libgeotiff library, commandline tools and supporting tables.
     Required by: gdal
libjpeg    (6b-3)
     A library for manipulating JPEG image format files
     Required by: gdal, libtiff
libjpeg12    (6b-2)
     A library for manipulating 12bit JPEG image format files
     Required by: libtiff
libmysql    (6.1.0-1)
     MySQL Client Library.
     Required by: gdal
libpng    (1.6.3-1)
     the official PNG reference library
     Required by: grass, qt4-libs
libpq    (9.2.4-1)
     The libpq library for accessing PostgreSQL + psql commandline client
     Required by: gdal, qgis-common
libspatialindex    (1.8.1-1)
     The libspatialindex library
libtiff    (4.0.3-2)
     A library for manipulating TIFF format image files (runtime)
     Required by: gdal, grass, libgeotiff, openjpeg
libxml2    (2.9.1-1)
     An XML read/write library
     Required by: spatialite
matplotlib    (1.3.0-1)
     Python plotting package
msvcrt    (1.0.1-4)
     Microsoft Visual C/C++ Runtimes
     Required by: grass, shell, openjpeg, msys, python-pil,
qgis-grass-plugin, qgis-oracle-provider, qgis-globe-plugin, pygments,
gdal-filegdb, gdal-oracle, networkx, pyodbc, setup, openssl,
qgis-common, oci, osgearth-libs, osg-libs
msys    (1.0.18-4)
     Minimal SYStem
     Required by: grass
netcdf    (4.3.0-1)
     The NetCDF library and commands for reading and writing NetCDF format
     Required by: gdal
networkx    (1.8.1-1)
     Python package for creating and manipulating graphs and networks
oci    (12.1.0.1.0-1)
     Oracle Instant Client
     Required by: qgis-oracle-provider, gdal-oracle
ogdi    (3.2.0b1-1)
     OGDI data access library (mainly for VPF reading)
     Required by: gdal
openjpeg    (2.0.0-1)
     OpenJPEG
     Required by: gdal
openssl    (1.0.1e-1)
     OpenSSL Compression Runtime
     Required by: curl, libpq, qt4-libs
osg-libs    (3.1.7-1)
     OpenSceneGraph (libraries)
     Required by: osgearth-libs
osgearth-libs    (2.4-1)
     OSG Earth (libraries)
     Required by: qgis-globe-plugin
pdcurses    (3.4-2)
     PDCurses (MinGW built)
     Required by: grass
proj    (4.8.0-2)
     The PROJ.4 library and commands for coordinate system transformations.
     Required by: gdal, grass, spatialite, qgis-common
proj-datumgrid    (1.5-1)
     Assorted PROJ.4 datum grid shift files
     Required by: proj
proj-hpgn    (1.0-1)
     PROJ.4 HPGN (HARN) grid shift files
     Required by: proj
psycopg2    (2.5.1-1)
     Python-PostgreSQL Database Adapter
     Required by: qgis
pygments    (1.6-1)
     pygments - syntax highlighting package written in Python
pyodbc    (3.0.7-1)
     Python interface to ODBC
pyopengl    (3.0.1-1)
     The Python OpenGLĀ® Binding
     Required by: grass
pyparsing    (2.0.1-1)
     Python parsing module
     Required by: qgis-full, matplotlib
pyqt4    (4.10.2-1)
     Python bindings for Qt4.
     Required by: qgis, python-qscintilla
pyqwt5    (4.10.2-1)
     Python bindings for qwt5
pyspatialite    (3.0.1-1)
     Python interface to SQLite 3 + Spatialite
     Required by: qgis
python-core    (2.7.5-1)
     Python core interpreter and runtime
     Required by: wxpython, python-numpy, python-pil, pyopengl, qgis,
python-help, pyqwt5, pyparsing, python-simplejson, python-shapely,
matplotlib, pygments, networkx, pyodbc, python-xlrd, python-xlwt,
python-win32, sip, pyqt4, gdal-python, psycopg2, pyspatialite,
python-qscintilla, python-dateutil, six
python-dateutil    (2.1-3)
     Extensions to the standard Python datetime module
     Required by: matplotlib
python-help    (2.7.5-1)
     Python documentation in a Windows compiled help file
python-numpy    (1.7.1-1)
     Python NumPy (Numerical) Extension
     Required by: grass, pyqwt5, matplotlib, gdal-python
python-pil    (1.1.7-1)
     Python Imaging Library (PIL)
     Required by: grass
python-qscintilla    (2.7.2-1)
     Python bindings for QScintilla
     Required by: qgis
python-shapely    (1.2.18-2)
     Geospatial geometries, predicates, and operations for Python.
python-simplejson    (3.3.0-1)
     python JSON encoder and decoder.
python-win32    (2.1.8-1)
     Python for Windows extension
python-xlrd    (0.7.5-2)
     Library for developers to extract data from Microsoft Excel (tm)
spreadsheet files
python-xlwt    (0.9.2-2)
     Library to create spreadsheet files compatible with MS Excel
97/2000/XP/2003 XLS files
qgis    (2.0.1-2)
     Required by: qgis-full, qgis-grass-plugin, qgis-oracle-provider,
qgis-globe-plugin
qgis-common    (2.0.1-2)
     QGIS (common)
     Required by: qgis
qgis-globe-plugin    (2.0.1-2)
     GLOBE plugin for QGIS
qgis-grass-plugin    (2.0.1-2)
     GRASS plugin for QGIS
qgis-oracle-provider    (2.0.1-2)
     Oracle provider plugin for QGIS
     Qt source code editing component.
     Required by: python-qscintilla
qt4-devel    (4.8.5-1)
     Qt4 headers and libraries (Development)
qt4-libs    (4.8.5-1)
     Qt4 runtime libraries
     Required by: qt4-devel, qgis-common, sip, pyqt4, qwt5-libs-qt4,
qscintilla, osg-libs
qwt5-libs-qt4    (5.2.3-1)
     Qt4 widgets library for technical applications (runtime)
     Required by: qgis, pyqwt5, qgis-common
saga    (2.0.8-1)
     SAGA System for Automated Geographical Analyses
setup    (1.0.7-9)
     OSGeo4W Installer/Updater
     Required by: shell
shell    (1.0.1-2)
     OSGeo4W Command Shell
     Required by: gdal, libtiff, libjpeg, libgeotiff, proj, curl, geos,
libmysql, sqlite3, netcdf, libpq, expat, xerces-c-vc10, hdf4, hdf5,
ogdi, iconv, pdcurses, zlib, fftw, libpng, wxpython, python-numpy,
pyopengl, avce00, gpsbabel, pyqwt5, pyparsing, python-simplejson,
python-shapely, matplotlib, gdal-mrsid, qt4-devel, gdal-ecw, setup,
libjpeg12, szip, libxml2, python-core, python-win32, sip, pyqt4,
qwt5-libs-qt4, psycopg2, pyspatialite, python-qscintilla, qt4-libs,
gsl-libs, libspatialindex, qscintilla
sip    (4.14.7-1)
     Python/C++ bindings generator (Development)
     Required by: qgis, pyqwt5, qgis-common, python-qscintilla
six    (1.3.0-2)
     Python 2 and 3 compatibility utilities
     Required by: python-dateutil
spatialite    (4.1.1-1)
     The SpatiaLite library for adding spatial capabilities to SQLite3 DBMS.
sqlite3    (3.7.17-1)
     The SQLite3 library for accessing SQLite3 database files.
     Required by: gdal, spatialite, python-core, qt4-libs
szip    (2.1-1)
     SZIP compression library
     Required by: hdf5
wxpython    (2.8.12-1)
     wxPython - Python bindings for wxWidgets
     Required by: grass
xerces-c-vc10    (3.1.1-1)
     The Xerces-C 3 library for parsing XML files
     Required by: gdal
zlib    (1.2.8-1)
     The zlib compression and decompression library (runtime)
     Required by: grass, libtiff, ogdi, openjpeg, gpsbabel, qgis-common,
qt4-libs, osg-libs
5. I install and QGIS is missing all the GDAL oriented menus under
vector and raster.
For fun I built a brand new Win 7 VM 64 bit and installed and had the
same thing happen there also. Everything seems to be working except QGIS
- and like I said it starts - but not with the correct number of tools.
Randal Hale, GISP
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
<mailto:rjhale at northrivergeographic.com>
twitter:rjhale
http://about.me/rjhale
