[Qgis-developer] R: Re: Re: Re: R: Re: attributeMap()
francescoboccacci at libero.it
Mon Feb 4 12:30:24 PST 2013
Hi Martin,
your code works fine. I used :
features = QGisLayers.features(vlayerA)
for inFeat in features:
from SEXTANTE module and it is not works properly.
so below code:
for inFeat in vproviderA.getFeatures():
idVar = inFeat [ index ]
working fine.
Thanks
Francesco
>----Messaggio originale----
>Da: wonder.sk at gmail.com
>Data: 04/02/2013 10.06
>A: "francescoboccacci at libero.it"<francescoboccacci at libero.it>, "qgis-dev"
<qgis-developer at lists.osgeo.org>
>Ogg: Re: Re: Re: [Qgis-developer] R: Re: attributeMap()
>On Mon, Feb 4, 2013 at 9:20 AM, francescoboccacci at libero.it
><francescoboccacci at libero.it> wrote:
>> Hi Martin,
>> this is my code:
>> vproviderA = vlayerA.dataProvider()
>> allAttrsA = vproviderA.attributeIndexes() #vettore contente
tutti
>> gli indici dei campi
>> try:
>> vproviderA.select(allAttrsA)
>> except:
>You cannot use getFeatures() like this: it returns a feature iterator
>which you need to use for accessing features - the state of iteration
>over features is not held there, not in the provider. This is the
>easiest way to use it:
>for feature in vproviderA.getFeatures():
> type = feature["type"]
> # do something with type
>Martin
