[Qgis-developer] Labeling: data-defined fields shifted after new vector API?
Larry Shaffer
larrys at dakotacarto.com
Wed Feb 6 01:20:16 PST 2013
Hi Martin,
On Wed, Feb 6, 2013 at 1:17 AM, Martin Dobias <wonder.sk at gmail.com> wrote:
> Hi Larry
> On Wed, Feb 6, 2013 at 4:25 AM, Larry Shaffer <larrys at dakotacarto.com>
> wrote:
> > Is mFields[i].originIndex (where mFields is a QgsFields vector) the same
> > index used for the keys in QgsFieldMap?
> No, it's not the same thing. "originIndex" is a mapping from layer's
> attribute indices to provider's indices. That's needed when one or
> more fields have been removed in layer's editing mode (and also used
> for identification of joined attributes). For example, if you have a
> layer with attributes attr1, attr2, attr3 and you decide to delete
> attr2, the index of attr3 will change from 2 to 1, but the originIndex
> will stay the same. Before new API merge, if an attribute was deleted
> in editing mode, indices would not change (because holes were
> allowed).
> > In other words, will this new method, QgsFields::toQgsFieldMap(),
> function
> > correctly [0]? If so, I can use it to attempt to auto-convert
> > QgsFieldMap-index-based data defined properties over to field-name-based
> > properties, without having think about reintroducing any QgsFieldMap
> > functionality at the provider level.
> That wouldn't help, because the numbering of fields has been changed
> on provider level (e.g. a provider used to return indices 0,1,3, now
> it returns 0,1,2), so I am afraid there's no simple way to establish
> mapping of attribute indices from old API providers to new API
> providers (because some have changed, others haven't).
Thanks for the explanation. Figured it wouldn't be that simple. So, is it
worth the effort to fix this (the 1.8 to 2.0 index issue)? I think many
users will find manually updating their data defined mappings, for every
layer in a project that has them, very annoying. This has the potential to
become a very large time-sucking problem for many users.
Could a lightweight QHash<old index, field name> be populated inline with
the current building of the attribute vectors; only for those providers
that would be different than before? The only-used-for-reads QHash could be
used to create an auto-update routine for data defined mappings. Is
something like that reasonable to implement? Is there another approach, or
any at all?
Regards,
Larry
> Regards
> Martin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130206/18cb84dc/attachment.html>
