[Qgis-developer] Labeling: data-defined fields shifted after new vector API?
Larry Shaffer
larrys at dakotacarto.com
Wed Feb 6 04:49:10 PST 2013
Hi Martin,
On Wed, Feb 6, 2013 at 3:38 AM, Larry Shaffer <larrys at dakotacarto.com>wrote:
> Hi Martin,
> On Wed, Feb 6, 2013 at 2:53 AM, Martin Dobias <wonder.sk at gmail.com> wrote:
>> On Wed, Feb 6, 2013 at 10:20 AM, Larry Shaffer <larrys at dakotacarto.com>
>> wrote:
>> > Thanks for the explanation. Figured it wouldn't be that simple. So, is
>> it
>> > worth the effort to fix this (the 1.8 to 2.0 index issue)? I think many
>> > users will find manually updating their data defined mappings, for every
>> > layer in a project that has them, very annoying. This has the potential
>> to
>> > become a very large time-sucking problem for many users.
>> As far as I know, it should be a problem only in data-defined new
>> labeling - field names are used in other places.
> Yes, definitely they should be moved to field-name-based data defined
> mappings. Even doing that, though, will require a means of auto-conversion
> (like with api change) to properly map the old index value to its field
> name, only once, to migrate over.
> > Could a lightweight QHash<old index, field name> be populated inline with
>> > the current building of the attribute vectors; only for those providers
>> that
>> > would be different than before? The only-used-for-reads QHash could be
>> used
>> > to create an auto-update routine for data defined mappings. Is something
>> > like that reasonable to implement? Is there another approach, or any at
>> all?
>> I think a real problem is there just with postgis layers - if I'm not
>> wrong, the holes in 1.x are appearing when geometry column is not at
>> the end of the list of fields, so for a layer with columns geom,
>> attr1, attr2 you would get attribute indices 1,2. As you can see,
>> implementing such mapping would be dependent on table structure. The
>> problem is that the stored indices get broken even with a change of
>> table structure - so even if we implemented some backward
>> compatibility for postgis (that would take table structure into
>> account), it might still cause problems.
> I understand, as this is the case with most of the labeled layers in my
> PostGIS projects. Many are created from shapefile imports, then the
> specialized labeling fields are added. Geometry column is basically never
> the last one. All of those layers are at least partially messed up, data
> defined-wise.
> My thoughts are to use that QHash in
> QgsPalLayerSettings::_readDataDefinedProperty to convert the stored field
> index property to its field name when the value is found to be an integer
> (indicating old-style index stored). I would also be saving the new field
> name mapping in a different property built off of the enum's literal string
> value, e.g.
> key="/labeling/dataDefined/Bold" value="label_bold"
> instead of
> key="labeling/dataDefinedProperty1" value="9"
> erasing the old index-based property on successful write of the new one.
> If the QHash is empty, then the current stored index value can be 'trusted'
> to map to the proper field name, i.e. provider never had holes to begin
> with. Does that make sense to you? Any ideas on adding such a backward
> compatibility QHash to the base data provider and implement it in just the
> postgres provider (unless there are others that had QMap hole issues)?
I implemented this in a very simple manner in a feature branch [0], which
is also available as a patch [1]. Using the following in PyQGIS console,
with a PostGIS layer selected:
pv = iface.activeLayer().dataProvider()
pv.palAttributeIndexNames()
returns for my test layer...
{0: PyQt4.QtCore.QString(u'id'),
2: PyQt4.QtCore.QString(u'Label_Text'),
3: PyQt4.QtCore.QString(u'Label_FontSize') ... }
which matches previous index-to-name mapping (geom column is index #1) and
can be used to fix the issue with QgsPalLabeling, make an auto-updating
function, and move to field name mappings. If run on a layer not PostGIS,
it returns an empty QHash, implying the fix is not needed for the provider.
However, I don't want to mess with data providers without sound advice from
those in the know. :^) Please let me know if such an approach is a
reasonable solution, I'm missing something, or you have a better idea.
[0] https://github.com/dakcarto/Quantum-GIS/tree/labeling_vector-api-fix_1 ,
https://github.com/dakcarto/Quantum-GIS/commit/a8bda0575db5783f53f44054a3a522953c9ffbcf
[1]
http://drive.dakotacarto.com/qgis/qgsdataprovider-qgspallabeling_patch.diff
Regards, and thanks for your help,
Larry
> Of course, regardless of adding an auto-conversion, if the user adjusts
> the table structure before the conversion is done there will be messed up
> field mappings, just like before. Since the conversion should only happen
> once on the first opening of the <2.0 project file (only time the QHash is
> used), there is a high likelihood the auto-conversion will transparently
> work with no issues. Then, the QHash fix can be deprecated sometime in the
> future.
> Also, moving to field name-based data defined mappings should allow join
> tables to function better for such mappings.
> Regards,
> Larry
> Martin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130206/7bcd1300/attachment-0001.html>
