[Qgis-developer] making QgsMapToolIdentify available to plugins
Etienne Tourigny
etourigny.dev at gmail.com
Fri Feb 8 07:47:26 PST 2013
I haven't really followed this, but I assume this does not affect
existing plugins which use QgsRasterDataProvider::identify() such as
e.g. the value tool plugin?
regards,
Etienne
On Thu, Feb 7, 2013 at 6:38 PM, Radim Blazek <radim.blazek at gmail.com> wrote:
> Hi Denis,
> On Thu, Feb 7, 2013 at 11:30 AM, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
>> Hi Radim,
>> I just finished the work thanks to Jef's debugging ability!
>> Here is the pull request
>> https://github.com/qgis/Quantum-GIS/pull/421
> pushed to master in 4e64d72.
> Thanks
> Radim
>> The identify method now returns directly the IdentifyResults instead of
>> using a private attribute.
>> Also, IdentifyResult is now a single struct (no RasterResult and
>> VectorResult)
>> Everything compiles fine and I tested it.
>> However, could you check that everything is ok regarding to the
>> rasterChanged?
>> Also, could you take care of accepting the pull request?
>> Thanks,
>> Denis
>> On 02/07/2013 11:24 AM, Radim Blazek wrote:
>> Hi,
>> sorry, I do not use IRC usually.
>> I would like to return to work in identify tool areas next week:
>> - copy feature from context menu
>> - better tree hierarchy for rasters
>> - propagate errors to user - probably just error messages as texts in tree
>> - instead of all that signals on format change just listen in action
>> and then call QgsMapToolIdentify and dialog functions
>> Please let me know when you finish your work in identify tool so that
>> we avoid conflicts.
>> Radim
>> On Thu, Feb 7, 2013 at 10:04 AM, Denis Rouzaud <denis.rouzaud at gmail.com>
>> wrote:
>> Hi Radim,
>> I have already merged the changes to return directly the results.
>> I am currently making a single struct for the results. I have a problem with
>> python files, an error in compilation I am trying to solve for some time now
>> without any success...
>> Would you have some time to give me hand?
>> Are you on IRC?
>> Thanks
>> Denis
>> On 02/06/2013 05:07 PM, Radim Blazek wrote:
>> Also, your changes to the raster result structure made me think that we
>> could use a single struct for both vector and raster result.
>> It might be easier to look into the results.
>> Any opinion on this? Nathan?
>> I believe, that It would be better to pass results to the dialog in
>> the original hierarchical structure instead of splitting them to
>> individual results and then reconstruct the tree searching for the
>> layer it should go into. For rasters the logical structure may vary
>> form one level for raster values (I would prefer to put band values
>> directly into layer item instead of adding additional level "feature")
>> to four levels for WMS with layer-sublayer-featuretype-feature.
>> Maybe some parts of QgsMapToolIdentify::identifyVectorLayer and
>> QgsMapToolIdentify::identifyRasterLayer, those related to creation the
>> tree in dialog should better be moved to QgsIdentifyResultsDialog?
>> I'll possibly add QgsRasterIdentifyResult and the dialog could work
>> directly with that or to use current QList<QVariant> returned from
>> raster identify().
>> yes,
> Qgis-developer mailing list
