[Qgis-developer] Several errors
Sanghee Shin
endofcap at gmail.com
Tue Feb 12 09:53:56 PST 2013
I updated my ticket and also attached setup.log.full there for your digging.
I just wonder whether there is any similar post-installation log file in Mac OSX and Ubuntu.
Thank you.
Sanghee
2013. 2. 13., 오전 2:27, Andre Joost <andre+joost at nurfuerspam.de> 작성:
> Hi,
> Am 12.02.2013 15:49, schrieb Sanghee Shin:
>> Basically I don't think it's the problem of Korean SRS but I believe
>> it's the problem of crssync. Anyway I would like to answer to your
>> inquires.
>> 1. Current srs.db missed EPSG code from 5167 through to 5188. This
>> means current srs.db missed at least 22 newly updated EPSG codes from
>> EPSG ver 7.9 or ver 8.0. When I run 'epsg_tr.py 5167 5188', I can
>> clearly get the full CRS information from GDAL. However I couldn't
>> see those CRSs from QGIS. Would you please test it out whether your
>> QGIS contains EPSG code from 5167 to 5188?
> In Lisboa standalone: no; in QGIS Master: yes (b9b943d, from November)
>> I tested it with QGIS 1.9.0 Alpha master nightly build version on my
>> Windows, Mac OSX and Ubuntu. And got the same result. And there is no
>> blanks in installation folder name. For example on windows,
>> c:\osgeo4w\... is my default folder name. So I believe that this can
>> be a bug of crssync.
>> I tried to find postinstall.log but I couldn't.
> Just saw that postinstall.log is only with standalone Windows version.
>> However I found
>> setup.log showing this kind of error.
>> *** 2013/02/12 13:42:30 running: cmd.exe /c
>> C:\OSGeo4W\etc\postinstall\sip.bat 2013/02/12 13:42:30 running:
>> cmd.exe /c C:\OSGeo4W\etc\postinstall\qgis-dev.bat 2013/02/12
>> 13:42:32 abnormal exit: exit code=-1073741511 2013/02/12 13:43:52
>> note: Installation Complete ***
>> Any idea on this?
> Well, thats not normal, and might be the reason for not syncing. There is also a setup.log.full, which might give further information at this points.
> Anyway, your ticket on hub.qgis.org should be updated. It has nothing to do with new or old EPSG codes.
> Greetings,
> André Joost
> Qgis-developer mailing list
