[Qgis-developer] Composer item's IDs
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Mon Feb 18 23:56:47 PST 2013
>Thinking about this. There really isn't a reason to force item
names/id to be unqiue . if I want to have three items named the same
then that is really my choice. If I have say three map windows that I
>want to set all to the same extents then I could just call them all
"maps" and just loop over all the items with that name.
There is use for both unique names (or auto-incrementing numbers) and
user-defined names. And both cases are already used:
- auto-incrementing number in QgsComposerMap::mId. Needs to be unique
within the composition because other elements may refer to it
(north-arrow items or overview maps)
- user-defined names: QgsComposerItem::mId (unfortunately with the same
attribute name as the composer map int id).
Regards,
Marco
> - sent from a tablet device that isn't an iPad
> On 19 Feb 2013 10:54, "Nathan Woodrow" <madmanwoo at gmail.com
> <mailto:madmanwoo at gmail.com>> wrote:
> Personally I'm not a fan of using a uuid unless the user doesn't
> need to enter them.
> For me a composer item only needs a id or name not both. You can
> just store a counter on the composer the item belongs to as only
> has to be unique for that composer. I would just auto name them
> "composeritem_n" and have the composer assign the name/id when the
> item is added to the composer. If the user wants to change it
> later he can.
> On 19 Feb 2013 10:38, "Olivier Dalang" <olivier.dalang at gmail.com
> <mailto:olivier.dalang at gmail.com>> wrote:
> OK I've got something which seems to work well using QUuid.
> It's easier with QUuid than an incremental id since there's no
> need to
> store the last key.
> It already works more or less, I'll make a pull request soon.
> What do you think about the other attribute ? (which would be
> called
> smthg like "Internal name", and would replace current id's
> behavior)
> I'm not sure this is useful though. Maybe it will only be
> confusing to
> the user...
> Should I add this attribute or not ?
> 2013/2/18 Nathan Woodrow <madmanwoo at gmail.com
> <mailto:madmanwoo at gmail.com>>:
> > Olivier,
> > I added the item id for that reason. Feel free to rework
> then so they
> > are auto generated and unique. That was my intention just
> never got
> > around to it.
> > - Nathan
> > Sent from some fancy phone looking thingo
> > From: Olivier Dalang
> > Sent: 19/02/2013 3:27 AM
> > To: qgis-developer at lists.osgeo.org
> <mailto:qgis-developer at lists.osgeo.org>
> > Subject: [Qgis-developer] Composer item's IDs
> > Hi !
> > I'm developing a plugin which needs to attach some custom
> data to some
> > Composer Item's instances.
> > Thus, I need a way to identify the instances.
> > I saw that there's an ID attribute in the ComposerItems, but
> don't
> > really know how it's supposed to work. It seems for now it's
> only an
> > user defined value, which remains empty when the user
> doesn't provide
> > it and which also can be duplicated.
> > So it seems I can't use this as an unique ID.
> > What's the best way to do that ?
> > More globally, what is this ID good for ? Is it's behavior
> not fully
> > implemented yet ?
> > I think it would be useful to auto-assign unique which the user
> > couldn't change. If needed, another attribute ("name" or
> "tag") could
> > be added to replace the current "ID" behaviour, allowing the
> user to
> > define custom data.
> > What do you think ?
> > Thanks !!
> > Olivier
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> <mailto:Qgis-developer at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130219/8cfa6b6f/attachment.html>
