[Qgis-developer] attributeMap vs. attributes
Richard Duivenvoorde
rdmailings at duif.net
Tue Feb 19 02:39:06 PST 2013
On 19-02-13 11:21, Sandro Santilli wrote:
> My topological editing plugin broke due to attributeMap() being replaced
> by attributes() in the python API. If I change to use attributes() it won't
> work with 1.8 anymore. Is there any important reason to require changes in
> all plugins ?
Hi Sandro,
I also had to update my plugins to reflect the api changes we go through
in 2.0 Although it is some work (for us plugin devs), I think it is good
te clean up and make a better api.
Here are the changes in the wiki:
http://hub.qgis.org/wiki/quantum-gis/API_changes_for_version_20
with on the bottom a way to handle it in plugins to handle both 1.8 and
2.x QGIS versions.
Martin wrote a lengthy email about the select and attribute changes, see:
http://lists.osgeo.org/pipermail/qgis-developer/2013-February/024278.html
Regards,
