[Qgis-developer] Print composer changes: several side-effects
Olivier Dalang olivier.dalang at gmail.com
Wed Feb 20 07:52:22 PST 2013
By the way : is there some policy about backwards compatibility ?
Thanks !
2013/2/20 Olivier Dalang <olivier.dalang at gmail.com>:
> Hi !
> Those change appear because some properties have been added and some
> removed to make the UI and the code more consistent (removing
> duplicate border color settings for Shape item, for instance).
> Upon opening an old project, the added properties will be set to
> default, while the duplicate one will take the old unused property.
> I'd say there's no easy way to avoid such side-effects (without coding
> some dirty compatibility code). One way to handle such changes would
> be to implement a kind of "old version file converter" to allow
> backwards compatibility without making the code too complex.
> But I'm not sure that if it's worth it. A general rule in software
> usage is to keep the same version of the software throughout a
> project, an to use new versions only when starting new projects.
> However, it is possible to discuss if which composer items should have
> a background and/or frame by default. (in your case, this could change
> whether composer items should have a background by default)
> For now, I think all the composer items have a white background and no
> frame by default, excepted the ComposerShape which has also a frame.
> Olivier
> 2013/2/20 Andreas Neumann <a.neumann at carto.net>:
>> Hi,
>> With the recent modifications in print composer, while I agree that the UI
>> has much improved, there are unfortunately also some side-effects. Here are
>> two problems I have detected:
>> * legend boxes which had a white background now have a transparent
>> background
>> * Basic shapes (like rects, ellipses, triangles) that had a black border now
>> have either no border or a white border
>> For organizations like us, with a lot of QGIS projects with a lot of
>> different layouts, this is quite annoying if we have to manually change each
>> of the projects.
>> But I am also aware that we are using master / unstable and that there are
>> modifications. I can live with such changes but I assume that other users
>> will have similar problems if backwards compatibility breaks.
>> Just to let you know - thanks for the improvements in the UI!
>> Andreas
>> Andreas Neumann
>> Böschacherstrasse 10A
>> 8624 Grüt (Gossau ZH)
>> Switzerland
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
