[Qgis-developer] contributing diffs
Larry Shaffer
larrys at dakotacarto.com
Fri Feb 22 17:42:57 PST 2013
Hi Vinayan,
On Thu, Feb 21, 2013 at 11:13 PM, vinayan <vinayan123 at gmail.com> wrote:
> I also believe a nice workflow should be in the qgis website somewhere.
> We have a brief one here at
> http://hub.qgis.org/wiki/17/GIT_Workflow
> Probably someone could update the above page and link it to the developer
> help pages..
> Below mentioned link mentions my workflow..what i observed with this is
> that
> I no longer need to do a force push..
> http://opengisdev.wordpress.com/2013/02/22/branch-based-workflow-for-qgis/
On the page you referenced above, step #13 will probably return something
like the following:
$ git push origin branch-test
To git at github.com:dakcarto/Quantum-GIS.git
! [rejected] branch-test -> branch-test (non-fast-forward)
error: failed to push some refs to 'git at github.com:
dakcarto/Quantum-GIS.git'
hint: Updates were rejected because the tip of your current branch is
behind
hint: its remote counterpart. Merge the remote changes (e.g. 'git pull')
hint: before pushing again.
hint: See the 'Note about fast-forwards' in 'git push --help' for details.
Regardless of whether the feature branch is part of a pull request, if you
locally rebased it (from master in this case) and have already pushed it to
your github fork, I believe you will always then have to do a force push.
Regards,
Larry
> http://osgeo-org.1560.n6.nabble.com/contributing-diffs-tp5035623p5036043.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130222/9e6105e8/attachment.html>
