[Qgis-developer] QGis build with Mingw64
Tim Sutton
lists at linfiniti.com
Sun Feb 24 01:29:50 PST 2013
Hi
Any particular reason you are using mingw rather than msvc 2008 (which is
well supported)?
Regards
Tim
On 24 Feb 2013 9:33 AM, "Theuns Heydenrych" <theunsheydenrych at gmail.com>
wrote:
> I am trying to build QGis with Mingw64 on windows.
> I have Qt64-4.8.4 on the machine and MSys and Mingw64.
> I have opened the CMakeLists.txt in QtCreator and set all
> the dependencies for Qgis in the opening wizard for QtCreator.
> When compiling i get the following error, can anybody give me some hints
> where to start looking, to get it compiled?
> Best Regards
> Theuns Heydenrych
> 09:11:03: Running steps for project qgis1.9.0...
> 09:11:03: Starting: "C:\mingw\bin\mingw32-make.exe"
> [ 0%] Built target version
> [ 0%] Building CXX object src/core/CMakeFiles/qgis_core.dir/qgis.cpp.obj
> src\core\CMakeFiles\qgis_core.dir\build.make:1234: recipe for target
> 'src/core/CMakeFiles/qgis_core.dir/qgis.cpp.obj' failed
> CMakeFiles\Makefile2:1118: recipe for target
> 'src/core/CMakeFiles/qgis_core.dir/all' failed
> makefile:145: recipe for target 'all' failed
> C:\dev\cpp\Quantum\src\core\qgis.cpp:48:27: error: external linkage
> required for symbol 'GEOPROJ4' because of 'dllexport' attribute
> C:\dev\cpp\Quantum\src\core\qgis.cpp:53:27: error: external linkage
> required for symbol 'GEOWKT' because of 'dllexport' attribute
> C:\dev\cpp\Quantum\src\core\qgis.cpp:66:27: error: external linkage
> required for symbol 'PROJECT_SCALES' because of 'dllexport' attribute
> C:\dev\cpp\Quantum\src\core\qgis.cpp:70:27: error: external linkage
> required for symbol 'GEO_EPSG_CRS_AUTHID' because of 'dllexport' attribute
> C:\dev\cpp\Quantum\src\core\qgis.cpp:72:27: error: external linkage
> required for symbol 'GEO_NONE' because of 'dllexport' attribute
> mingw32-make[2]: *** [src/core/CMakeFiles/qgis_core.dir/qgis.cpp.obj]
> Error 1
> mingw32-make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
> mingw32-make: *** [all] Error 2
> 09:11:06: The process "C:\mingw\bin\mingw32-make.exe" exited with code 2.
> Error while building/deploying project qgis1.9.0 (kit: Desktop 64)
> When executing step 'Make'
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130224/fbc345a4/attachment-0001.html>
